Results 1 to 13 of 13
Thread: Whater drops on bottle surface
    Jun 2003
    Hyderabad, India
    4
    any one have idea for how to add whater drops on this coke bottle surface in lightwave.
    thanks.
    hmm well initially i would think you could make the object an effector in sticky mode, then spray particles on it and play with hypervoxels. you could also, if its a still image select points on the outside of your object, create a new object that is the outside points, import it into lightwave and apply hypervoxels to those points. In a lightwave tutorial they mention that particles systems are in no way directly linked to hypervoxels, but are just usually assosiated with eachother
    Kansas
    1,610
    You may check out preset central. I seem to remember something there
    http://www.presetcentral.com
    Registered User Stewpot's Avatar
    West Mids England
    116
    I'm sure I remember seeing something along these lines from Splinegod, and that he used HV's.
    You would need to search the forums for it.
    Remember! - It isn't the fall that hurts, but the sudden stop at the bottom!
    MY GOSH!
    that is hella cool!
    how did u make the bottom of that bottle
    For any help I am given, thank you ahead of time!
    MW4 - Retired
    MechLivingLegends - 3d modeler
    COD4 Player
    Bronson Ferri
    Back from Monkey Island Weetos's Avatar
    May 2003
    France
    943
    the light probe image and the table remind me the jack daniel tuto...
    concerning the water drops, I would use hypervoxels applied to randomly selected points, I think that should do the trick
    Hastings, New Zealand
    7,731
    You dont need particles to do it. You can use HVs generated directly on the object iself of even use geometry.
    Heres an example from my water fx CD.
    The problem with using particles is that you have no control over placement and you end up with spherical drops. If you notice the drops on this are more random and hug the surface better.
    Registered User Hervé's Avatar
    Europe-Luxembourg
    2,421
    Best advice if U go for a still is to model them with real goemetry....
    This simple approach should work... but I fear it needs some overhaul!
    It worked for me many times!
    Modeler:
    1 - Make a copy of your poly geometry
    2 - Delete all polys and keep vertex only
    3 - Keep only needed vertex to create groups for every drop
    4 - Save the vertex object
    Layout:
    5 - Load vertex obj
    6 - Parent it to poly object
    7 - Activate HV on vertex obj
    8 - Play around with HV Surface settings
    Bye.
    Visit 3D Recursions :: 3D Math for Art Places
    plus Attractors Art! and My own old and ancient Site!
    "Everyone needs something / Sometimes they don't know why / But so much good's been misunderstood / In the blink of the eye / So I take a little bad with the good / It ain't just black and white" Iggy Pop
    Oct 2003
    Tigre, Bs. As., Argentina
    42
    Hi mmkrishna, my name is Ezequiel and I'm wondering if you can post some reply to my "Coke Bottle Trouble" thread because I'm going mad at this model and I can't seem to finish it.
    Maybe I'm doing something wrong, I don't know.
    I will appreciate your help, thanks in advance,
    Best regards and happy holydays,
    Ezequiel
    Jun 2003
    Hyderabad, India
    4
    Hi Ezequial here i am posting some screen shots for coke bottle may be it will help you.
    Jun 2003
    Hyderabad, India
    4
    one more pic
    Oct 2003
    42
    Heeeyyy, thank you very much mmkrishna
    I think that your pics will help a lot,
    When I look at them I think I can see my model problems become resolved
    Thank you again
    I hope I can help in the future,
    Best wishes and happy holydays,
    Ezequiel
