Thread: Chromatic aberration in glass
    Mar 2012
    Japan
    123
    Hi, for my second post today I would like to ask if anyone have a recipe to cook some nice CA in a glass material...
    here my reference:
    thanks
    Nov 2003
    jersey
    5,792
    Sure...
    You can use the dispersion setting in either dielectric or refractions to do this... though the effect can often lack "punch" and you have little control.
    For designing a custom effect, the simplest way is to use multiple refraction shaders, each set to a slightly different ior, split out to a colour component from each, and then recombined back into a full spectrum.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Mar 2012
    Japan
    123
    Thanks RebelHill for the fast reply! I was not even expecting a solution and here I got a fast and easy one. Very appreciated. I'll try this right now.
    Mar 2012
    Japan
    123
    You absolutly need to add Refraction blur to get that effect? (Adding blur make the renders so long...)
    Nov 2003
    jersey
    5,792
    Im not using any blur... Difference refraction indices on each node, not blur vals.
    And btw... for an effect following the basics of reality... You use the green ior as teh "standard" ior for your material... red refracts slightly less, blue slightly more.
    RHN Nodal Tutorials
    Aug 2010
    Kernow
    2,079
    It looks great! Nice and simple too.
    Mar 2012
    Japan
    123
    Excellent!
    Is there's a way to blur the refraction without using the standard Blur Refraction that is so long to render?
