Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: Not able to move things in Layout?
    Mar 2014
    United States
    8
    Hi. I'm unable to rotate or move objects and cameras in Layout. Anyone have any idea on why that might be? Thanks in advance.
    Have you pressed "t" to move and "y" to rotate before?
    Mar 2014
    United States
    8
    I have. The axis appear, but when I click them, they don't react. I'm unable to alter bones, as well.
    You can lock channels by pressing on the [H] [P] [B] or [X] [Y] [Z] buttons on the lower left hand corner, you can also lock items in the scene editor by turning the lock icon on.
    Nov 2003
    jersey
    5,766
    and this happens if you just flat start a new scene and try to move camera or light?
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    hi, could be many things, check this video >
    9 FAQ -
    Camera won't move, the Camera is not selected - 0:00
    Camera won't move, you are mixing up the Camera with the Perspective view - 0:50
    Camera moves in an unexpected way, you must fix the camera curve in the Graph Editor - 21:30
    Camera moves in an unexpected way, you have changed the Coordinate System
    Camera moves in an unexpected way, the Camera has adjustements to the motions, like parenting or targeting. press "m" with the camera selected to get to motion options.
    Camera won't move, motion channels are locked - 33:30
    Camera won't move, the Move or Rotate tool is not selected
    Camera won't move, you have locked the camera in the Scene Editor
    Perspective View. It is not possible to render the perspective view. The only way to do this is by previewing it in VPR. It is also not possible to animate the Perspective View, you will have to animate the Camera View.
    Mar 2014
    United States
    8
    Still won't work. Here is a video of my plight.
    https://www.youtube.com/watch?v=V50t...ature=youtu.be
    and nothing is locked in the scene editor? (Ctrl+F1)
    Mar 2014
    United States
    8
    Everything is unlocked. Nothing's happening.
    I've always been here Mr_Q's Avatar
    Burbank
    340
    Do you have Depth of Field/Moblur preview turned on? I realize this would affect only the camera view, but just in case.
    Kevin "Q" Quattro
    Inhance Digital
    3D Art Director
    Nov 2003
    jersey
    5,766
    Hmmm... locked or not... handles should light up when you click on them, which clearly isnt happening. What happens if you use the spinners next to the channel box entries (bottom left)... or if you open the graph editor, and drag the key positions about... do things move then?
    RHN Nodal Tutorials
    hm, quite strange, share the scene maybe... ?
    input device is correct under Preferences / Generic ?
    Axes grinder- Dongle #99
    Seattle
    14,729
    Puzzling... btw, fwiw I rarely click "on the arrows" unless I have to restrict movement. In general I just click and drag in a clear area, that will affect the Selected item, assuming you don't auto-select something else.
    W/o sharing the Scene it's not possible to fully debug the issue: there might be movement modifiers applied to the all the items, or something analogous. Is there any reason you can't share the Scene?
    Watched the video, but didn't see if you tried the minisliders on any of the axes.
    Praise to Buddha! #resist
    Sep 2005
    Earth
    3,121
    Are there expressions connected to those Items or Nodal motions?
    Pessac
    5,051
    If you switch to Layout's Modify tab, which of the tools is highlighted?
    B
    LightWave 3D Trial Edition
