Thread: distorted Layer A
    Oct 2013
    Netherlands
    2
    distorted Layer A
    Hello,
    Hopefully somebody can help me with the following problem:
    A made a live set in Photoshop and load it into VSE. The "layer A" distorted when I move the layer. Larger and smaller is no problem, but move from right to left or from top to bottom is a problem. There you see a large distortion. In previous projects there was no problem. Anyone have an idea?
    Can you post a picture?
    Are you using the VSE UV map to setup layer A?
    Oct 2013
    Netherlands
    2
    Kane,
    Thx for this simple tip :-)
    I copied the layer from a previous project and that was the problem. The EXR from the tricaster was the problem solver!
    Twitch.tv/SCGTour
    Sep 2013
    Roanoke, VA
    41
    Also make sure Keyable is set/not set as appropriate. I had a problem where VSE was marking a layer Keyable that needed clean edges (and it broke them).
