Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Thread: Free Script: Split Frame
  1. #16
    Quote Originally Posted by oliverhotz View Post
    there also a version of it in odtools.
    ah, i wasn't sure - please what is the name to find it inside the plugin crowd?
    3dworks visual computing
    demo reel on vimeo
    instagram
  2. #17
    its called LWS Splitter.. under 2018 / setup
    Oliver
    OD Tools Purchase Link: http://origamidigital.com/cart
    Vimeo Channel: https://vimeo.com/channels/850417
    Join ODRoot - https://www.odroot.com
  3. #18
    great, thanks!! PS would be really nice to have a sort of cheat sheet for all OD tools, as they are growing and some times the right ones are not too obvious to find in the plugin jungle. maybe it could be something like a single page PDF with all the plugins listed by function groups.
    demo reel on vimeo
    instagram
  4. #19
    if you are on the internal discord, or the facebook page, there's a single page pdf with it all.
    - - - Updated - - -
    here you go.
    ODToolsListOfVideos26oct2018.pdf
    Oliver
  5. #20
    - - - Updated - - -
    here you go.
    Hi Oliver. Is it possible to create a script which divides up the whole frame into segments but wihout the limited region function? So for
    each segment we need a unique new camera (positioned with horizontal and vertical lens shift and the possibility to give some Overlap).
    The reason is that Octane Denoiser does not support renderings higher that about 4k resolution and is not able to make use
    of the limited region border on function. "The render region is always working over the full image frame buffer."
    I´ve have to render a about 19.000px x 19.000 px image with octane. At the moment there is no possibility to render
    out such bigger resolution images with the use of denoiser.
    In the Octane editor there is also the possibilty to lens shift the camera. But its not easy to setup in good way.
    A workaround by hand would be adjusting the Octanre Render Target Camera Lens Shift X and Lens Shift y and
    "cutting " the image again by giving a negative Overscan value in Lightwave Camera settings. But its very complex
    if in my case a lot of rows and columns are needed.
    Iam sure that iam not the only one who needs the possibilitiy of rendering high res pictures with octane.
    Maybe this would a really useful feature for many LW-Octane users.
    Greetings
    Here also link to octane forum thread:
    https://render.otoy.com/forum/viewto...69158&start=10
  6. #21
    you can file a feature request on my page for it (link mentioned in the registration mail)
    Oliver
