Results 1 to 15 of 17
Thread: Smoothing Groups or similar?
    Aug 2013
    Chile
    15
    Hi, I am having trouble with some lighting on spherical meshes when exported to Unity 3D. For more detail read my thread here: http://forum.unity3d.com/threads/225...rical-geometry
    I have recieved an answer that says I should try using Smoothing Groups. Now I have read a few stuff about smoothing groups but it seems this is not available in Lightwave.
    So I was wondering if there is a tool in lightwave 11 for editing vertex normal, maybe a plugin. Any help appreciated!
    thanx
    Open edges. Export OBJ. That's the only way to generate Vertex Normal maps in Lw...
    Yes, sadly you can't make smooth groups in LW (Lw don't have tools for creating them) so just try what probiner suggested to see is it gonna work.
    RAM-Studio
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,134
    Then you can load that obj back in modeler and merge points and save it as lwo, obj or fbx and your vertex normals will look like the unwelded obj exported first.
    Aug 2013
    Chile
    15
    Talking Ok
    Ok guys I'll give this a try, I'll let you know how it went!
    Thanx
    Aug 2013
    Chile
    15
    Arrow No luck yet
    Quote Originally Posted by malteins View Post
    Thanx
    Hi, so I have come to a better outcome by following your suggestions of opened edges and exporting as .obj and then re-importing, nevertheless there's still some problems with how the baked lighting is acting on spherical objects.
    As you can see, I have horizontally based opened edges. Maybe this is not the way to go, one might also think that only 1 vertically based open edge could provide better results.
    Can you post zip with unitypackage? (Object as fbx exported from Layout)
    Aug 2013
    Chile
    15
    FBX version
    Quote Originally Posted by MarcusM View Post
    Hi, sure here's the file exported from Layout in .fbx format (2012).
    http://m1.malta.cl/tester.zip
    I've been using this method (.fbx export from Layout) since I started using Unity with Lightwave. I've read this is the way to go. Anyway I realized that spherical meshes have problems with Lightmapping, hence this thread started and I was recommended to export in .obj format in order to get the Vertex Normals to show up correctly. I've tried this but still not getting correct results which you can see here:
    As you can see in the image, when I show the Lightmapping resolution grid it gets distorted in some areas ( the squares don't match up ), so I'm thinking this is happening because of a wrong UV mapping method I'm using, basically the UV mapping on the spherical part of the mesh. Here is an image where you can see how I have set up the UVs.
    Now I am wondering what I could do to fix this issue. I am thinking this might have to do with the 2nd UV channel that is used for Lightmapping. I don't know if UV2s are editable in Lightwave, I've heard a few other apps let you do it.
    Well any guidance, tips or ideas you might have, all are very welcomed.
    Thanks a lot to all of you guys who have already helped!!
    Aug 2010
    Kernow
    2,078
    What does this one look like in unity?
    Attached Files Attached Files
    I mean Unitypackage that means when you create prefab then click on it RMB and create unitypackage.
    Unity making own UV for lightmapping, what you know, if in importer you turn on this. When you have two your own UV on object you can use one for lightmapping. In object importer is option "swap UV".
    http://docs.unity3d.com/Documentatio...mappingUV.html
    Aug 2013
    Chile
    15
    No luck yet
    Ok, here you can download the zipped unitypackage of the object in question : http://m1.malta.cl/unitypack.zip
    1) I exported my model from Modeler into Layout,
    2) then exported it from there to .fbx,
    3) afterwards importing it to Unity and making a prefab,
    4) which I exported then as a UnityPackage.
    Anyway you'll be able to see what I've been mentioning in the pictures, there seems to be a problem whenever I lightmap a spherical mesh. I really tried many options but still no luck.
    Hope you can find some indication of the problem with this package.
    Thanks!
    Aug 2013
    Chile
    15
    Cool Thanks
    Quote Originally Posted by XswampyX View Post
    Hi, I've tested your version but I am still getting the same artifacts and strange shadings on the spherical part of the mesh.
    In the image you can see what I'm talking about, I've placed your model in the scene and ran Lightmap. That's all.
    Anyway, thanks for your help, I do think we're getting closer to solve this.
    I think i found what was wrong.
    Chek your lightmap (also in preview) when in model imporetr setting will be scale 0,01 and 1. There should be always 1.
    In layout export scale should he 0.01, in Modeler 1.0.
    Check also this great plugin for lightmapping with image-based lighting, Path Tracer GI, and Monte Carlo GI.
    https://github.com/mstevenson/Lightmapping-Extended
    And maybe you try bake texture, then object on scene not must be static.
    http://forums.newtek.com/showthread....texture+baking
    Aug 2013
    Chile
    15
    Hi, thanks for the links, I was already aware of Lightmapping Extended, I use it pretty much all the time. Also I have done what you say about the scale, I always export from Layout at 0.01 and then in Unity set the import settings to 1.
    Anyway I really don't think the problem has to do with the import o export settings, since I have applied different smoothing groups in Modo 701, exported the model as .lxo
    and still I get the same artifacts and shading problems with the spherical part of the mesh when Lightmapping the object in Unity. You can see this here:
    Attachment 120029
    In the image the mesh has a .lxo file extension, exported from MODO with a Vertex Map. You can still see the problems that I had before at the beginning of the thread.
    I think this problem is due to the way I set up my UVs. You can see them here:
    Any suggestions, maybe I should have mapped the spherical top portion of the cylinder with "Planar on the Y-axis (top down)" ?
    Thanks in advance
    I tested this today, baked lightmap with import scale in Unity 0,01 and saw problem from your images. After bake with scale 1 it was good. Tomorrow i will check this one more time and attach print screens.
