Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: Can you set a Tricaster to do a double box or squeezeback?
    Dec 2013
    Madison, WI
    10
    Do Tricasters have the ability to do multi source functions like double boxes, or squeezebacks? If so how do you set something like that up? Our Tricaster is an 855.
    You can do a double box in a virtual input. There are presets that you can load or you can do it manually using the positioner controls with the A, B and Overlay channels.
    There isn't a way to perform a squeezeback. There is zooming control available in the virtual input that mimics it a bit, but it isn't the same thing and you need virtual set editor (VSE) to edit the zooming start/end locations.
    19,354
    Well, you kinda sorta can - using one of the Expand transitions and a DSK, for example - you could probably 'Macro' that, and or use an M/E and key layer in similar fashion ... or, if it was static, the positioner.
    NYC
    3,333
    No macro on TC855 but using ASC, you could design a squeeze box via a DSK or try the built in ones like Steve suggested.
    You could also get someone proficient in ASC and VSE to possibly design a custom transition and/or LiveSet to suit your needs.
    PS I know of one such person if you pursue that route
    Jose Burgos
    NewTek Certified Trainer
    www.burgosfx.com
    FaceBook
    Twitter @NYTriCaster
    19,354
    Quote Originally Posted by joseburgos View Post
    ... or try the built in ones like Steve suggested.
    If memory serves, going back to vt, this is why there are keystroke shortcuts to move the tbar to halfway.
    NYC
    3,333
    Yup
    Jose Burgos
    www.burgosfx.com
    FaceBook
    Just to follow up on this, you can perform this effect using specially crafted Transwarp transition. It need to be a TriCaster with Transwarp effects support for this to work (TC410/460/860/8000, 40v2, 455/855).
    Download the attachment and setup the switcher as follows.
    Program: Full screen source
    Preview: M/E or Virtual input with the 'Helix Small Big' set
    In the main switcher transition, load either the Left or Right effect to match which box the full screen video should squeeze into. Then perform a transition to make it work.
    Helix DVE.zip
    You will need to use After Effects (or another similar tool) to create effects that works with other box effects.
    19,354
    Can you not just use the standard transitions (such as Expand L)?
    That would be close, but the effect that are attached will squeeze perfectly into the double box effect.
    19,354
    Aah, or course ... forgot we weren't just discussing the generic squeeze (that's what happens when you don't bother to reread the whole thread)
    Oct 2012
    Munich, Germany
    80
    Hello,
    btw.
    how to create Transwarp Effects ourself ?
    In ASC i found nothing about doing this.
    We would need some special sort of effects like the "Alien Hand", any hint is highly welcome.
    Best regards,
    Walter
    TC8000 / TW850
    Cables: Belden 1694/Canara Connectors
    Cams: Sony PWM-EX3, Sony HDR-CX430/BMD HDMI2SDI
    19,354
    See sections 2.2 and 2.5 in the ASC (2.x) manual.
    Read those sections of the manual.
    To produce the animations you can use anything. After Effects, Lightwave, Nuke, Avid DS....
    The application for producing for the warp sequence animation MUST support 16-bit or 32-bit per pixel color for it to work. The other animations would be 8-bit per pixel color.
    Oct 2012
    Munich, Germany
    80
    Very nice idea to use a uv texture to do such animations.
    Since when is this feature available or better since what version ?
    best regards,
    Walter
    TC8000 / TW850
    Macro Titan JonRaidel's Avatar
    Sep 2009
    Los Angeles, CA
    216
    FYI: Ive been using the tricaster and ASC for DoubleBoxes and Squeezebacks. there is not a 100% perfect way using ASC to do a squeezeback. if you design properly you can get it CLOSE. but not perfect.
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    Panasonic HDX 900 Cameras
    NDI Connect Pro
    Graphic Outfitters ScoreHD
    Graphic Outfitters Scorebridge
    Livetext 3 w/ LT [Scoreboards 2]
