Thread: Depth of Field sampling quality
    I generally get pretty nice results with LW's Depth of Field, however I'm about to set off an animation with the subject in a very shallow DOF and so the blurry bits are very blurry, but not smooth, a little grainy. Apart from upping the sampling is there anything else you can do to smooth it out?
    I'm happy with the look, it just needs to be less grainy.
    Registered User davidsenna03's Avatar
    Feb 2011
    Bogota, Colombia
    62
    Hey! You just might need to increase the number of samples. If that doesn´t do the trick you can always blur ir a bit in After Effects or Nuke.
