Thread: Copy Project or Default Settigns
    Jan 2010
    Sarnia, Ontario
    6
    I use the 425 for hockey, the same way every time, with one file per game that we do.
    Right now, I have to create a new session from scratch and re-adjust all of the settings to be where I want them and rename all of the playlist pages each time.
    If I was able to create one master session, and then save that as my template, and then clone that session and re-name it to the current date/game then that would save a lot of time and tedium.
    This could be located in there somewhere, but I have not found a way to do it as of writing this.
    19,396
    Just as a bit of info - 3Play 4800 has a session template system, which is effectively what you're looking for. (You could probably do something like this manually on a 425 or 820 by duplicating session folders from Windows, but admittedly it would be a pain.
    Oct 2015
    Nixa, MO
    10
    Ditto!!!!!! such a pain...
