Results 1 to 2 of 2
Thread: animating issues
    Nov 2003
    up in the North of Scotland
    78
    animating issues
    I am wanting to animate 4 bolts slotting into a hole with washers and sleeves slotting in also. I have animated one set of the bolt/washer/sleeve slotting in and i was wondering if there is an easy way to copy the keyframes over to the other 3 sets so they are all synchronised?
    Also when i set key frames up for rotating the bolt, the bolt moves first the wrong way and then spins round the right way. I think this is something to do with curves??? can you switch curves off for one object?
    thanks
    alistair
    Unknown Cavern
    930
    The answer to your second quesion is that you need to set you may need to set a few key frames to "linear" in the graph editor.
    Or adjust the controls to remove the odd motion. The Linear is a quick fix, but may not look like u want it too.
    As for the 1st question, just clone the object, then click on "Move Path" in the motion options (Item tab, near bottom of menus in Layout 7.5c)
    Current system Specs:
    4gb ddr2 1066
    dual 9600 gt (512mb each) running SLI
    9600 black edition amd
    780a nvidia chipset
    XP Pro or XP Pro 64 or Windows 7
