Page 1 of 22 12311 ... LastLast
Results 1 to 15 of 325
Thread: Basic stuff Lightwave users should know, but are not-so-obvious
Hybrid View
    I'm sure there have been topics like this before discussing things in Lightwave sometimes considered "hidden gems" and whatnot... but I think it's time to re-visit this. Perhaps even some of the long time veteran users among us will learn a new thing or two!
    THE IDEA FOR THIS THREAD:
    There are native functions in Lightwave that a lot of users take for granted... some of which are almost invisible and are somewhere between hard and impossible to discover. So the big question is this: What is a basic Lightwave function that you feel the average user would likely not find, but is something you consider important to know about generally speaking? (both modeler and layout)
    To demonstrate, I whipped up a really quick video about the statistics panel to kick off this thread:
    Bonus tip courtesy of Tobian: Volume select works with things like "hide selected". Try it!
    EDIT: Do a search on Erikals's videos when posting and include them if they are relevant to your post... because chances are good he covered a few things that are likely to get mentioned
    London
    2,338
    I'll get the ball rolling with a couple of really basic yet useful GE shortcuts (and by way of subscribing to the thread!):
    Select Keyframes, Press F1, LBM left/right will quickly allow you change the TCB Spline Tension.
    Another simple yet over looked option in the GE: Filter Static Envelopes. Turning on will only show channels with keys on them - really useful if you have loads of nodes/instance animations going on.
    Im not sure how many people make use of it but if you hit 'i' in modeler it will bring up the ino panel where you can get the coordinate values for the X,Y, and Z of a vertex or group of vertices and copy them. Useful when you want to line up geometry on the same axis coordinate by using the set value command. 'v' for set value, paste your coordinates in dialog window and hit ok..
    Kamehameha Chameleon BigHache's Avatar
    Sep 2006
    Future Past Life
    1,899
    Quote Originally Posted by hrgiger View Post
    I do this quite a lot actually.
    I bind Bridge to left-mouse menu then have Deselect All to right-mouse menu. It makes for super fast filling of holes.
    Stuck in a very big cube Waves of light's Avatar
    South Yorkshire, England
    2,500
    'Align to last point X' (or Y or Z) - hidden in the menus. Select any set of points, then select one more and use those to align to a specific Axis.
    'Select Path' - select two polys, points or edges and use it to complete the selection between the two.
    Systen Spec: i7 4930k (OC @4.5ghz),ASUS p9x79 MB, 32GB Ballistix RAM, H60 cooling, Samsung SSD 120GB, WD 1TB
    Axes grinder- Dongle #99
    Seattle
    14,732
    Cool
    (away from machiine) trying to remember how this one works....
    IF I'm remembering this correctly:
    The Graph Editor has its own set of hotkeys, that OVERRIDE the main set when the GE is open. If this is driving you crazy, UNassigning them in the hotkey editor will allow them to work as usual in the main UI even when the GE is open.
    POINT SELECTION
    If you've just made a complicated (ie, PITA) point selection, get in the habit of creating a Point Set. Better, make a hotkey to make it even faster-- mousing down to the Selection Set thingy is slow slow slow slowwwww. A hotkey will make this convenient and more likely to become a Good Habit.
    POLY SELECTION SETS
    Although PARTS should be the polygon equivalent to Point Sets, they are not (dammit, LAME) because the contents cannot overlap. However, using SEL POINTS gives you the equivalent by switching from selected points to the equivalent in Polys.
    SELECTION BY COLOR
    You can select by Sketch Color.
    (ps: I LUVVV these kinds of threads!!! Thanks, Chazriker-- we should probably start one every 3 months just to noodge folks.)
    Praise to Buddha! #resist
    Seattle
    14,732
    Even experienced users forget this one:
    People coming from other apps often think there's no "Soft-selection" in LWM. Technically true, but there is FALLOFF.
    Falloff can be either spacial, or moderated by a Weight Map. While not as slick as most implementations of 'soft-select', Weight-mapping can give modelers arbitrary control over how a Tool is applied to a mesh. Plus, you can have MULTIPLE weight-maps on the same geometry, so you can have multiple ways of applying tools to the same geometry.
    Mar 2006
    in lights
    2,167
    so this thread is becoming like legendary Tips and Tricks Book cool keep'em coming
    Seattle
    14,732
    Only 994 to go.
    I love these types of threads!
    -Light is an optical illusion-
    CPU:2x E5-2687W (2x 8 cores + HT = 32 threads @ 3.2GHz) MOBO:ASUS Z9PE-D8 WS RAM:64gb HD:Revo 3 x2, 240 OCZ SSD, 4TB WD BLACK
    Website:interocitor-media.com/tardis
    Registered User tommyc's Avatar
    Mar 2013
    Atlanta
    53
    As a new Lightwave user, I really appreciate threads like this. Huge thanks to everyone.
    automator of tasks xchrisx's Avatar
    Nevada
    593
    Blog Entries
    6
    One thing I wish I knew when I first started Lightwave is that if you want similar functionality to Mute Channels when keyframing animation, you can add an expression to a channel with "0" as the expression's value. Then just disable the expression when you want to "Unmute" it.
    My Lscript Collection | LinkedIn
    3D Generalist IGT
    Things that I've found a couple of experienced LW users didn't know about Modeler.
    1. You can bind "deselect all" to a key, instead of clicking on an empty section of the interface
    2. bind PickSurf to a key. you can now click on any polygon and the surface editor opens up and highlights its' surface, click on another polygon with another surface and the surface editor selects it.
    3. You can use Absolute size, to measure things, but also to scale them to exact dimentions.
    4. Spin Edge to change how a quad is triangulated. [/] or [\]
    5. Snap drag tool works inside the UV window too.
    6. Almost any box where you can enter a number you can also enter simple formulas like 360/7+5
    7. In those numeric boxes you can use metric and imperial numbers mixed toguether. 20"+2m -.2'
    Mar 2006
    in lights
    2,167
    I guess it will be one of the greatest thread ever.. May be at the end there will be an edited version as PDF... First community user based - PDF - tips and tricks.
    Newbie Member
    Sep 2017
    Dhaka,Bangladesh
    28
    Quote Originally Posted by tyrot View Post
    is the PDF file ready? or i have to wait more? waiting for the link
