Page 3 of 22 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 325
Thread: Basic stuff Lightwave users should know, but are not-so-obvious
  1. #31
    Axes grinder- Dongle #99
    Seattle
    14,726
    Yeah, it's a good utility. As to remembering, same thing w/Weld Points, someone else's pet peeve.
    Praise to Buddha! #resist
  2. #32
    Quote Originally Posted by chazriker View Post
    ....My only gripe about Motify is that it doesn't remember your last-used keyframe settings between uses... aside from that, motify is superior to normal delete key in every way.
    and that it doesnīt delete keys in the Surface Editor (at least until LW 11.5).
    As previously, NT says that is not a bug, itīs a feature request, even though the manual says otherwise:
    from LightWave 10 Help file:
    ....This includes all envelopes applied to those items (like Camera Zoom Factor and Light Intensity), envelopes for applied plug-ins (such as Morph Mixer channels), and surface envelopes applied in the Surface Editor.
    ciao
    Thomas
    Web: www.dieleinwandhelden.com
    I use two pieces of the three-piece application with mocap module.
  3. #33
    Not every user know about hierarchy mode in Modeler Layers window ;p
  4. #34
    How Old? Really? Aww Heck colkai's Avatar
    Staffordshire
    7,808
    Quote Originally Posted by MarcusM View Post
    <<raises hand>> Well, frak!
    Too old to die young.
  5. #35
    London
    2,336
    By default, three simple keyboard shortcuts in Layout that will get you motoring along (this is on a Mac, not sure of similar PC keys):
    alt D - clone an item without the popup
    alt N - opens popup for renaming an item
    alt C - clone a null with instances applied. Also useful, select an item you want to instance, using alt C will create a null and apply the selected item to it as an instance. Very quick and handy!
  6. #36
    Quote Originally Posted by raw-m View Post
    In my opinion is missing something like Duplicate in Layout. Try clone object etc. with sliders, parent/ target items, item shape(draw line to) etc. Only way is load item from scene. (Or i don't know something?)
  7. #37
    Registered User tyrot's Avatar
    Mar 2006
    in lights
    2,162
    what s that hierarchy mode???
  8. #38
    automator of tasks xchrisx's Avatar
    Nevada
    593
    Blog Entries
    6
    Hierarchy mode lets you parent more like the scene editor rather than the pull down method that the list option provides. Here is an example:
    edit: Forgot to put, this is in Modeler's Layer Window
    My Lscript Collection | LinkedIn
    3D Generalist IGT
  9. #39
    Seattle
    14,726
    The LWM Layers Panel has so much potential... but I got tired of making mockups that were ignored. >|^P'''''
    There's so many semi-hidden features maybe something is wrong with the basic design philosophy. Ideally, we shouldn't be so happy to see this thread.
  10. #40
    South Yorkshire, England
    2,500
    Quote Originally Posted by xchrisx View Post
    Well, after all these years and I never knew you could do that!
  11. #41
    Seattle
    14,726
    Quote Originally Posted by Waves of light View Post
    That control might be EXCESSIVELY subtle. Ya think?
  12. #42
    2,500
  13. #43
    You can copy UV map TO another(copy vertex map) but must write name, wy not choose from list? ;] (Right click on Vertex Maps window)
    Another not so abvious thing, in my opinion is: You can export wanted UV map for each material in FBX if in material Color you choose wanted UV but not must choose texture/image.
  14. #44
    Mar 2006
    in lights
    2,162
    thanks chris for the image... wow never clicked there..
  15. #45
    Another good thing in LightWave that some may overlook is that all entry fields that require numeric input are able to accept math operations. So if you didn't know the exact value you wanted but knew you wanted to double something in size, you could just enter (existing value) *2 and will give you computed result.
