Page 21 of 22 FirstFirst ... 1119202122 LastLast
Results 301 to 315 of 325
Thread: Basic stuff Lightwave users should know, but are not-so-obvious
  1. #301
    Super Member tburbage's Avatar
    Redwood City, CA
    383
    In Modeler, you can assign various viewport attributes using "Save View Preset" to the NUMPAD numeric keys. I'm using this mostly to be able to switch between what it calls "Rendering Style" (Color Wireframe, Texture, Textured Wire, etc.) using the numpad keys, but reserve a few for switching between Quad, 1+3 vert, and 2-side-by-side layouts. See "Save view Presets" in the 2015 manual for how to do the assignments.
    But an undocumented tip is, for example, if you have the 1 key assigned to just switching the current viewport to Textured Wire, if your pointer device is hovering over a "neutral" part of the interface (where you can click to deselect all) rather than a specific viewport and you hit that key, all of the viewports will be set to Textured Wire. This can be very handy when you just want to quickly switch all viewports between a wireframe view then back to a solid shaded view.
  2. #302
    Apr 2016
    Barcelona, Spain
    568
    Quote Originally Posted by tburbage View Post
    Testing it! Thanks!
    English is not my native language so please be patient.
    Salvador Ureña
    http://urenasalvador.wixsite.com/portfolio
  3. #303
    Axes grinder- Dongle #99
    Seattle
    14,732
    Cool Selection reminders: subtracting selections using the STATS window
    SELECTION: sometimes it's easier to Select the INVERSE of a given property, than to select for a property itself , such as "# of points".
    see this thread for an example: http://forums.newtek.com/showthread....ected-polygons
    Remember you can UNSelect (Subtract From Selection) in the STATS window.
    Remember you can select polys by SKETCH COLOR-- assigning a different Sketch Color to specific polys may make your life easier, and that's more flexible than...
    PARTS: remember PARTS exist, but a polygon can only be a member of one (or zero) Part.
    That "(or zero)" can be useful too: basically it's "Select everything that ISN'T Assigned to a Part".
    Remember INVERT SELECTION exists.
    Polygon Selection in the STATS window can be by COLOR, PART, SURF, # OF VERTICES.
    Praise to Buddha! #resist
  4. #304
    or in plain English/American (take you pick) a bug, and a very annoying bug at that, catches me out every so often
    And the keyboard shortcut to assign windows is CTRL+ALT (at least on a Mac) and standard convention is to assign Five to TOP, Two to Front, Eight to Back, Four to Left and so on with Nine being Bottom, but its up to your personal taste really
  5. #305
    San Jose, CA
    6,511
    Quote Originally Posted by gerry_g View Post
    Given that it follows the LW "dogma" that "when nothing is selected, everything is selected" (in this case, w.r.t. viewports), what makes you so sure it's a bug?
    John W.
    LW2015.3UB/2019.1.4 on MacPro(12C/24T/10.13.6),32GB RAM, NV 980ti
  6. #306
    because no selection is required for the proper action either, ergo bug !!
  7. #307
    Pessac
    5,067
    I always use 1 for Wireframe, 2 for Texture, 3 for Texture wire and 4 for weight. I don't change anything else since you can use Display Options to change the Layout if you need to.
    B
    LightWave 3D Trial Edition
  8. #308
    Seattle
    14,732
    B
    I never use the keypad for the display properties, except for "5", which is "center the quad". I do use them for quad positioning, tantamount to "Landscape" and "Portrait" modes.
    ::checking:: Apparently whatever other presets I may have had got lost in some *.cfg catastrophe (why are *.cfgs so fragile???).
  9. #309
    London
    2,339
    Tired of the Gradient Node showing the order all wrong if you don't Show Inputs in order? Do this:
    https://youtu.be/jrhhqi5YT0Q
  10. #310
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,138
    The Node editor has actually a undo system with more than one step.
  11. #311
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,678
    Quote Originally Posted by raw-m View Post
    I like that, that's a good one to know.
    Thanks Mark
  12. #312
    Cumbria UK
    419
    Just spotted this gem in the LW manual..
    In Layout, to select an item, press ' and a popup appears in which you can type the name of the item you want (or the first letter or two..) Press enter, item selected.
    For items with similar names (Null1, Null2, Null3, etc) It'd be great if some sort of filtering/predictive text was added...
  13. #313
    "OH NO!", Joseph Joestar ncr100's Avatar
    San Francisco
    1,100
    Blog Entries
    2
    Quote Originally Posted by kyuzo View Post
    That is awesome. Item selection by name.
    Predictive text for item selection would be rad. And I hope a similar feature for Tool selection which uses more than just the tool's name because some of the tool names in Lightwave are not intuitive to their behavior so maybe there could be some search-keywords associated with Layout (and Modeler) Tool plugins to support predictive tool discovery.
    -Nick
    audio: Ö ¤ wk Py
  14. #314
    Seattle
    14,732
    Quote Originally Posted by ncr100 View Post
    Let's extend that feature request: allow user to TAG tools with keywords that make more sense to the users than the programmers. This would especially be good because it builds in an extensible capability for 3rd party plugins.
  15. #315
    Sep 2017
    Dhaka,Bangladesh
    28
    Quote Originally Posted by tyrot View Post
    I guess it will be one of the greatest thread ever.. May be at the end there will be an edited version as PDF... First community user based - PDF - tips and tricks.
    is the PDF file ready? or i have to wait more? waiting for the link
