Page 11 of 22 FirstFirst ... 91011121321 ... LastLast
Results 151 to 165 of 325
Thread: Basic stuff Lightwave users should know, but are not-so-obvious
  1. #151
    More of a warning than a feature:
    Pressing "s" while the Surface Editor has the focus does NOT save a file, it creates a preset (which, to be complete, IS saved).
    Not anymore in 2015, it's fixed/corrected there .
    RAM-Studio
  2. #152
    Axes grinder- Dongle #99
    Seattle
    14,732
    Quote Originally Posted by Lewis View Post
    Yer killin' me, Lewis!!! $$$ --January, just... hold... out... 'til.... January......
    Good to hear! What's the default hotkey for Create Preset?
    Praise to Buddha! #resist
  3. #153
    There is button on surface editor which saves it so shortcut is really not needed (i hit the shortcut by mistake liek 99% of time wantign to save scen einstead preset ), especially one which interfere with Saving scene. Also i think F9 is also improved. Now whichever window/panel you are IN (a slog as it's lightave panel OFC) if you hit F9 it renders i.e. no need to click on layout window to start rendering, small change but usefull on daily basis .
    Lot of those workflwo fixes/changes in LW2015, good work LWG3D .
    RAM-Studio
  4. #154
    Seattle
    14,732
    Cool
    ::high-five::* I have SOOOoooooo many inadvertent presets for the same exact reason. Gahd that was annoying.
    A preset button is OK, but there should be some provision for hotkey (low low low priority on that one). And, as a registered AHK fanboy, I'll point out that everybody can MAKE a panel-context-sensitive (!!!) for the SE to implement "Create Preset" for themselves.
    *(In USAian culture, ::high-fives:: denote enthusiastic & sympathetic agreement. )
    /pedantry
  5. #155
    London
    2,338
    Only found this out today....
    In Modeller if you have a Weight Map and you want to add another Weight Map but need to see the first one for reference, do this - goto 8:20:
    https://www.youtube.com/watch?v=-k4mDqBli6U#t=501
  6. #156
    Registered User rdolishny's Avatar
    Peterborough, Ontario, Canada
    313
    Point Normal Move
    This could be the default for Translate, in fact I remapped [shift][ctrl] T to it.
    Any selected points are moved in the direction of the normal as opposed to the direction you slide your mouse (left, right, up, down). This is CRITICAL for sculpting geometry, pushing and pulling points in and out.
    The only thing missing is weight falloff, but that doesn't mean it isn't there. I can't find it but this is a great start.
  7. #157
    Not So Newbie Member
    Oct 2008
    Melbourne, Australia
    25
    These shortcuts and hints are killer!!! Nice one
  8. #158
    Seattle
    14,732
    Pasting: The Paste TOOL -- two different types of geometry pasting
    Besides the normal Paste command, there is also a Paste Tool.
    The Paste command ( ctrl+v ) will always paste the geometry in exactly the same place it was when it was Copied.
    The Paste TOOL allows you to copy geometry from the buffer, and interactively place it with the mouse.
    • Create some geometry
    • Select it
    • hit "ctrl+v" (or in my case, just "v", because I remapped it) to copy the selection into the buffer
    • find the Paste TOOL in your menus
    • Invoke the Paste TOOL (i.e. hit the button)
    • LMB click to see the geometry, drag it around in multiple viewports
    • RMB click to deposit a copy of the geometry at the current location
    • LMB click to position more copies, etc....
    Here's a small UI downside:
    I don't think the Paste Tool is mapped by default into a menu. Unfortunately, (and indescribably stupidly) when you assign the Paste TOOL it shows up on a button as simply "PASTE". Infuriating. Rename it so you know it differs from "Paste", use LMB to place and RMB to paste copies, and go crazy.
  9. #159
    Dec 2004
    San Juan Island
    4,686
    • Select it
    That would be ctrl+c, yes?
  10. #160
    Seattle
    14,732
    Dammit! Yes.
    But, here c=copy and v=paste, no ctrl key required, 'cuz that's the way I set it.
  11. #161
    Aug 2006
    Eureka, CA
    6,962
    Falloff can be very useful, and very confusing. It's a plus though.
    shrox www.shrox.com
    Heavy Metal Landing
  12. #162
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,923
    When using "Load from Scene" double clicking on "Objects", "Light" and "Cameras" will deselect/select all the "Objects", "Light" and "Cameras" respectively.
  13. #163
    South Yorkshire, England
    2,500
    Quote Originally Posted by Snosrap View Post
    No way! Nice one.
  14. #164
    Aug 2014
    South Bend, Indiana
    398
    I've mapped 'U' to 'Select Loop'. Comes in extremely handy when making selections of an arm or pole. You can just select a loop all the way around the grow your selection shift+[.
    Also you can select loop of two edges and bridge them to connect two pieces of geometry, doesn't always work but when it does it's awesome.
    Also, pancake voxels are badass.
  15. #165
    2,500
    Quote Originally Posted by squarewulf View Post
    If you really want to be clever, you can use AHK (Auto Hot Key) to map the mouse wheel to loop, loop expand and select next loop. But AHK only works on Windows.
    Check out the last post in this thread to see how I do it:
    http://forums.newtek.com/showthread....lect-Connected
