Thread: Pegboard
    Mar 2008
    Prince Edward Island
    492
    Pegboard
    Hello. I am trying to create a pegboard like the attached but it is crashing my Modeler when I try to perform a Boolean. Is there an easier way to do this, or would anyone have this low file they might be able to send?
Name:	Screen Shot 2013-12-02 at 3.55.20 PM.jpg
    Nov 2003
    jersey
    5,767
    If you're trying to make a "box" and boolean into that, Id suggest first trying instead to just cut into a single flat poly, and then extrude that out after.
    Alternatively, it may well be the large number of intersections thats sending it a bit mad... try instead to make a lil 2X2 square, then use the array tool to multiply it and stitch them together to form the whole board.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Sep 2005
    Earth
    3,121
    You can texture it if it's just a single poly or model one hole and than make an array.
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,923
    Subdivide your box a couple of times before attempting the boolean. Or maybe just use Julienne with several cuts. Or knife it a couple of times before attemping the boolean. You get the picture. You won't get any crashing and the boolean will perform a whole lot faster.
    Mar 2008
    492
    Thanks all. I got it to work by shutting down, and only running Modeler. I imported an eps of the pegboard, extruded and it worked!
