Thread: Publish Queue Unlisted youTube & wierd DDR playback
    Oct 2013
    United Kingdom
    37
    Two questions:
    1) Is there anyway to configure the publish queue for youTube to upload as Unlisted? Even if I set the default as unlisted from within youTube it seems to override it and make it public immediately?
    2) When I record something, then click add to DDR1, if I play back the file back to program or preview from DDR1, the green channel is just.... missing. Ideas?
    Ta
    T
    I was going to say channel settings, but I noticed you said you already tried that... so I wouldn't know what else would affect the "defaults" in that way.
    as for #2, I'm not sure what you're referring to. You mean livestreaming on YouTube?
    Oct 2013
    United Kingdom
    37
    RE: 2 - specifically, if I record the program out, i.e by pressing record with the 'add to DDR' option enabled (this is on a 460 BTW), the resultant file which ends up in the DDR doesn't appear to have a green channel. It's most odd. The file itself if fine if exported/added to youTube, but if I try and use it in the same session, it does this.
    NewTek Engineering QA VideoEng QA's Avatar
    Sep 2011
    San Antonio
    163
    Thanks for taking the time to post the issues you are having!
    Regarding the first, it is true that we create clips that currently do not regard public/private settings for the YouTube account or channel. We've brought this to the attention of our engineers for consideration as a feature request.
    On the second item, it sounds like you may have LiveMatte or possibly the procamp enabled here. LiveMatte being enabled by default is set to key green and would quickly explain the apparent lack of green on output but not in the recorded file. Can you check to see whether this may be the case?
    Thanks,
    Jeremy Brosius
    For bug reports, feature requests, or technical inquiries: https://fogbugz.newtek.com/default.asp?pg=pgPublicEdit
    Oct 2013
    United Kingdom
    37
    Quote Originally Posted by VideoEng QA View Post
    Great, many thanks - would be most useful. Often encodes take 6 - 10 hours, so I like to leave it going overnight, then check it the next day before making it public!
    !Doh. That's blatantly it. I was mucking around with something the other day, and almost definitely checked that box. Not in front of the Tricaster at the mo, but yep, that's going to be it.
    Thanks!
