Thread: Sound mapping TC 855 analog input multi channel recording
    Feb 2011
    Stockholm
    25
    I have a query about conecting 4 channels of analog audio to a TC 855 and we want to output these separate via embedded SDI.
    If I conect XLR to 1a, 1b, 2a, 2b. Will that output SDI embedded audio 1,2,3,4?
    Macro Titan JonRaidel's Avatar
    Sep 2009
    Los Angeles, CA
    216
    On the audio input settings, you must select 'Line Quad' for this to happen
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    Panasonic HDX 900 Cameras
    NDI Connect Pro
    Graphic Outfitters ScoreHD
    Graphic Outfitters Scorebridge
    Livetext 3 w/ LT [Scoreboards 2]
    Feb 2011
    Stockholm
    25
    Quote Originally Posted by Snowjogging View Post
    So if I set line quad then it adds all the 1a, 1b, 2a, and 2b to the quad sound output in embedded SDI?
    Sep 2009
    Los Angeles, CA
    216
    it should yes
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    NDI Connect Pro
