Results 1 to 14 of 14
Thread: Thickness Thickener
    Mar 2008
    Prince Edward Island
    492
    Thickness Thickener
    Hello. I remember using the Thickness feature in the new versions of LW, but I went to user it and it is not there. Any ideas? I am on a Mac Pro running version 11.6.
Name:	Screen Shot 2013-11-08 at 4.49.03 PM.jpg
    I can only think of two possible reasons: 1. it didn't get added for some reason on your latest install or 2. your menu configuration is using an older configuration. Add core_tools.p and go to edit/edit menu layout and on the top choose the preset "default"
    Mar 2008
    492
    Thanks, but my Default is greyed out. See attached.
Name:	Screen Shot 2013-11-08 at 5.18.28 PM.jpg
ID:	118061   Click image for larger version.
Name:	Screen Shot 2013-11-08 at 5.18.16 PM.jpg
    Hmm no idea, It's not the only tool you are missing, Chamfer is also missing, I would try erasing all configs and reinstalling. (back them up if you have done some tweaking)
    Member steve0077's Avatar
    Sep 2005
    California
    155
    Look under utilities tab/additional/thickener
    15,103
    Best to simply go to edit menu, search for thicken, and drag it to the multiply window tab and place it under extend, that is were it should be.
    if it isnīt showing up in the edit menu, you need to scan the folders for plugins.
    Michael
    Mar 2008
    492
    Thanks, I went into Utilities and no luck, and I did a search in the Edit Menu window for thickener and no luck. I launched my 11.5 version and it is there. I am trying to see if it can lot but no luck. How do I reset the ap or do I need to do a new install?
    Mar 2008
    492
    Ha, I tried Danner's tip about the Cor Tools again after a restart and all is working!
    Thanks folks for all your help!!
    15,103
    Quote Originally Posted by Stephen0523 View Post
    you canīt search for thickener, it can only find the absolute correct command..which is thicken, that may be why you didnīt find it.
    also ..you could have scanned your folder for the plugin, if it by any chans wasnīt recognized as loaded.
    But it all worked out it seems anyway, just to remember next time, search for the exact names, and learn to scan folder, and even manually locate the plugin with
    windows explorer etc.
    Michael
    ... and even manually locate the plugin with
    Michael
    That'd be kind of hard since he is on a mac ;o) For third party plugins is viable to search on the hard drive, but lots of native tools get bunched up in one .p file. Modeling_pack.p Modeling_tools.p Core_Tools.p Conv3d.p etc all hold several commands inside them.
    Axes grinder- Dongle #99
    Seattle
    14,732
    ... next time, search for the exact names, ....
    Actually, isn't the lesson "DON'T search for exact names, search for shorter versions of the name" ? That's what I do, because it's crazy how people mangle the names of things.
    Praise to Buddha! #resist
    San Jose, CA
    6,506
    Right, and even then they might put another word in front of it or such. I find the best approach if something's "missing" is to pull up the Plugins panel, switch to "File" mode, and (in the case of "native" tools) check and see if any of the usual suspects aren't listed, indicating problems. In the case of third-party plugins, it's easier because you usually know the file name and can check the list to see if it's still present (and if not, try to re-add it).
    John W.
    LW2015.3UB/2019.1.4 on MacPro(12C/24T/10.13.6),32GB RAM, NV 980ti
    15,103
    maybe...best to make sure to know the plugin though, if you donīt you might not even get it right with a shorter version of the name, but whatever works...shorter name search will
    also bring up other equally named plugins if such are available, which means you have to jump through several plugins, but itīs one way to go about it
    search for thicken with t or th, and you see what I mean, if you are fairly confident about what it is called, you will find it quite fast
    So to save time I would do a name search after what you think it is or been told it is called, if that fails, search for lower amount of letters.
    It might be handy to have a plugin/menu edit search which progressivly search and finds while you still have the search window open, and not start it up
    as two modules.
    Michael
    Seattle
    14,732
    Well, "th" is TOO short, but "thick" (iirc) only gives 2 measly hits, which are a lot easier+faster to click thru than attempting to correctly type some random combo of letters an apparently drunken programmer thought would be cute to designate their plugin/script with. EG, "Slidex2-3" versus "Slide-X2.3" and that kind of mishegas.
    Just throwing out successful Search strategies here: I use the Menu Editor as a very VERY lame HELP system all the damn time.
    Certainly ANY kind of non-modal (i.e. "always available") help system would be big help, Blender is particularly nice in this respect, and I suspect MAYA may have this covered in their usual overkill way. 'Progressive' is a good idea, as you say, in that you can often see the answer 'way before you finish typing the Search.
