Thread: Wired Tablet Midi
    Macro Titan JonRaidel's Avatar
    Sep 2009
    Los Angeles, CA
    216
    Wired Tablet Midi
    does anyone have a setup using a WIRED Tablet through Midi? iOS or Android
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    Panasonic HDX 900 Cameras
    NDI Connect Pro
    Graphic Outfitters ScoreHD
    Graphic Outfitters Scorebridge
    Livetext 3 w/ LT [Scoreboards 2]
    Sep 2009
    Los Angeles, CA
    216
    UPDATE:
    Was able to get TouchOSC working with the Alesis iO Dock using the WIRED USDmidi cable.
    Outside of my complications due to setup (no internet allowed) after I installed the Alesis iO Dock Window's Drivers, it worked fine.
    Currently Im using one of the TouchOSC templates that come on the app just to make sure the midi commands are working.
    The next step in the process is trying to figure out how to make my own template given the current no wifi/internet complication. I might have to do it at home on my personal wifi :/
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    NDI Connect Pro
    Glad to hear that is working with the Alesis iO Dock.
    Sep 2009
    Los Angeles, CA
    216
    my next question would be if the ipad would work using just the camera connector? maybe the computer would see the ipad as a usbmidi device instead of just an 'ipad' ?? I feel like just plugging an ipad into the system wouldnt allow midi to work.
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    NDI Connect Pro
