Results 1 to 15 of 21
Thread: Wire Bundle Along Path
    Sep 2006
    Future Past Life
    1,899
    Hoping someone can help me automate this modeling process a tad.
    So I have this bundle of wires that has been rail extruded. Pretty straight-forward. I would like to put a spin on the bundle along the path. I'm hoping there's a better way to do this than modeling the bundle straight, then apply the spiral, then modify that bundle to my curve. Any suggestions?
    Use the same curve used in the rail extrusion process to create skelegons... got o layout and convert skelegons to bones, rotate the bones... save transformed and load back into modeler. shouldnt take but a couple minutes to get teh result you're after.
    Sep 2006
    Future Past Life
    1,899
    Brilliant, thank you. That should do it!
    Nov 2006
    Burbank, California USA
    4,576
    You could also keep your wire bundle as a rig instead of save transforming it out. This way if you have to modify it you just adjust your rig setup.
    Profile piece
    2010 Reel
    'The X's' Reel
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,675
    There's also bryphi77's "motion info extrude" tutorial that does something similar to what you want.
    http://m.youtube.com/watch?v=_WV7ApjIsh0
    Hope it helps
    14,890
    Unless youré not supposed to animate it, and model is only what you want?
    I would use px_bezier, free plugin...check erikals youtube clip on how to twist a cord, if that is something close to what you want?
    http://www.youtube.com/watch?v=IVK5q2jVUwc
    The plugin...
    https://www.lightwave3d.com/assets/p...try/px_bezier/
    Michael
    Super Member Hieron's Avatar
    Aug 2006
    Netherlands
    1,685
    Consider using DP Spline Transform
    It is awesome, interactive, Layout based and can be built upon. Reverse engineering a specific path may be a pain though, the question is whether that path is needed exact as it is..
    I'm no fan of locking stuff into position in modeler when interactivity can be kept in Layout.
    Sep 2006
    Future Past Life
    1,899
    Thanks for all the helpful suggestions. I'll def give more of these a go tomorrow at work. Nothing in the model is locked, just looking for an effective way to knock out a shot and expand my skillset.
    Super Member SteveH's Avatar
    Albuquerque
    477
    Also doesn't LWCad have something that would allow you to twist as it extrudes? I dont' have LW on this machine so I can't find the exact name of it (sorry).
    Somewhere between the Darkness and the Light
    Nov 2006
    4,576
    If LWCAD doesn't, which I'd be surprised if it didn't, there's Rope Editor.
    http://www.next4d.com/
    Profile piece
    2010 Reel
    'The X's' Reel
    Axes grinder- Dongle #99
    Seattle
    14,727
    It would entail a lot of back and forth, but doesn't PATH EXTRUDE allow this....YES. Attached is a screenie of a five disk object extruded using a (sloppy) Camera path.
    Praise to Buddha! #resist
    South Yorkshire, England
    2,500
    You can set up a LWCAD spline and then use Profiler to extrude along the spline. Then selecting any point along your spline, rotate to twist the profile.
    This also allows you to keep the original spline, should you want to add in a secondary wire or profile.
    EDIT: Sorry, edited this bit out as it was a bit misleading. I don't think you can save multiple shapes as profiles (e.g. 6 circles in your case - starting points for the wire ends).
    Jun 2004
    Suffolk, UK
    106
    Quote Originally Posted by Hieron View Post
    +1 the more 'modeling' you can do in layout the better...
    this is a pretty good summary of what it can do
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,131
    You can also use Magicbevel for this.
    Dec 2003
    Portugal
    1,819
    for this I would use Hair blade (http://d-creation.sakura.ne.jp/plugin_latest.htm )...you create a profile in modeler, in this case a few circles, then draw the curve with any curve tool, and apply the hair blade. you can edit all the points in the curve, twist, scale, etc. and it's always editable. When you want to render you simply freeze the curve and it even makes uvs for you.
