Thread: weird polys after import
    Hi everyone,
    I have a very complex model. After the import from MOI3D, I have weird result at the render, it look like if the polys are getting out of the model. Someone know how to repair this?
Name:	weird polys.jpg
    website:
    http://www.soap3d.com
    email:
    [email protected]
    Available for freelance!!
    Dec 2004
    San Juan Island
    4,686
    How to they look in Modeler?
    Aug 2006
    S
    3,511
    They look like double ups where you have an identical polygon occupying the same co-ordinates or there are flattened quads in between. Or non subD'd polygons, or geometry which needs to be tripled because of where it is. Try "shift I" and the stats on subs, flattened quads switch to wire and zoom in "Shift A".
    South Yorkshire, England
    2,500
    Unwelded points on a sub-d model? Press W and see if there are some sub-d and some non-Sub-D polys. Merge points (M) and then TAB to change all polys to sub-D.
