Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: Can I replace all layers in a layout object with the same layers from another?
    May the sauce be with you starbase1's Avatar
    London, UK
    5,617
    Subject line pretty much says it all - I have a complex object with many layers set up in a scene, and I'd like to replace all layers from one version with all layers from a different version.
    I can do it one layer at a time, but it would be a lot less error prone and time consuming to do the whole lot in one hit. Is this possible?
    LW 11.5
    Nick
    Faith is the opposite of Intelligence.
    Touched by his noodley appendage!
    My Lightwave Graphics & Downloads!!!
    it's a manhole cover ↓ JoePoe's Avatar
    Jun 2006
    LISA
    1,969
    Can you, with layout closed, simply rename the new object with the old objects name and place it in the the right path?
    (do whatever naming backup dance you need to do first of course).
    Once that's done, with both open, save the object with the name you really want and it will update automatically. Yes?
    System Specs: A pile of sand, a couple of wires, a real live mouse and a beer.
    South Yorkshire, England
    2,500
    You can open up the .lws file in a text editor and do a find and replace on the object ID. But be careful, backup everything first before attempting this.
    For instance, in my current scene file there is a line that I believe calls the object file and then places it in the scene:
    'LoadObjectLayer 43 10000016 Objects/_MyProjects/Arch_Viz/Football_Stadiums_Brazil2014_obj/Maracana_Stadium_v048.lwo'
    so I would just do a find and replace using:
    to
    Football_Stadiums_Brazil2014_obj/Maracana_Stadium_v049.lwo
    Save the file and see if it opens up in layout correctly, then incrementally save your scene file, just to be on the safe side.
    I messed up one of my scene files, because I did the above routine and there were instances of a single referenced objects and it didn't seem to like that. When I re-opened the scene file, it took ages for it to load and there were no instances of the object in the scene.
    EDIT: And by instance, I mean Add | Clone | Clone Instance.
    Cheers,
    Ricky.
    London, UK
    5,617
    Thanks for the suggestions - I had thought of renaming away the object, but then other scenes that use it would not find it. And the manual editing of the scene file is a bit of a kludge...
    Given that there are replace with object commands, I was hoping to have missed an option with this. The way it works at the moment feels like a hangover from when object files had only one layer...
    Axes grinder- Dongle #99
    Seattle
    14,739
    If I understand what you're saying: YES, it does seem like a hangover.
    When one replaces a "object" which is a layer in a multi-mesh, shouldn't we get a dialog asking if all the other objects/layers from that new source file be replaced also????
    This seems like the kind of SIMPLE "feature" that could (and maybe HAS) be easily addressed with a script. "Better Object Replace.lws" would be a good name.
    Praise to Buddha! #resist
    Nov 2006
    Burbank, California USA
    4,576
    If you replace the first layer associated with an object it will swap out all the layers associated with it.
    However, if you've imported a layer manually, that layer has no relationship with the first layer as that "load object" operation is separate from your other "load object" operation.
    I was working on a script that made doing this more intelligent. I believe Dodgy was as well. The problem is that there's no way to get the index id of a layer. Checking which layer is what is done by comparing the name of the layer so the script is dependent on someone giving all their layers unique names. If all the layers are called "unnamed" then the script will fail. I'd say submit a request to get index id via lscript/python. Then you, or we could finish our scripts.
    Doing a find/replace in a text editor on the lws file is your quickest solution right now.
    Profile piece
    2010 Reel
    'The X's' Reel
    Seattle
    14,739
    so there's no programmatic way to determine the source file name, and search the scene for similar?
    Is the id# you refer to on the Layout or the Modeler side?
    I'm hoping they get this facility into Python: seems like that would be a really handy bit of info to have accessible.
    Jun 2006
    LISA
    1,969
    Quote Originally Posted by starbase1 View Post
    ....but then other scenes that use it would not find it.
    "My" methods specifically addresses this.
    Once the new file is in place and renamed give the original it's original name again. It will be where it needs to be and named correctly for everywhere else it's used.
    It sounds convoluted but it's really only four naming steps.
    It's a little like an easy setup of the classic Tower of Hanoi game.
    Nov 2006
    4,576
    No, there is a way. My script works for my needs but I'm also very careful to give my layers unique names. So it works. However for me to release it as a gift to the LW Community, I'd want it to be as fool proof as possible. The current way we can determine Modeler layers is not fool proof
    It'd be on the model file side...so it wouldn't be specific to L or M.
    Profile piece
    2010 Reel
    'The X's' Reel
    Seattle
    14,739
    Nick, perhaps a helpful adjunct would be a Modeler script that at least gave simple unique names to all unnamed layers.
    SIDE NOTE: I almost always have more Hidden layers than Visible/Active -- in fact I've requested a preference switch where all Layers START as Hidden*, and are only made active by user intention-- and usually I'll add an "NV" to a Layer Name to indicate/document that I don't want to see the layer. (*This would prevent the common-for me- mistake of when I make, say, a CUTTER layer, and it gets sent to Layout when I don't want it to.)
    If I were to write the script above, I'd add a function where "Occupied but non-visible Layers" got names that started/ended in "-NV-".
    Nov 2006
    4,576
    Define "simple".
    If the LWG can add the layer index that'd be the best solution, instead of some wonky hack workaround. Submitting a feature request would be my suggestion, instead of someone spending the time to make a lscript that has limited usefulness.
    Profile piece
    2010 Reel
    'The X's' Reel
    2,500
    Thanks for this Nick, it'll be interesting to see what you come up with.
    Seattle
    14,739
    more is MORE
    Quote Originally Posted by nickdigital View Post
    Define "simple".
    Yes. I'd probably go with"Auto-(systemclocktime)", or "NV-Auto-(systemclocktime)" in the case of a non-visible layer. Or, the Layer Number. (The latter has the advantage of brevity, and I'm still not happy how hard LW makes it to see and USE long layer names.)
    Obviously, the more parameters LWG can expose to Python and LScript (which they should probably just abandon, as Bob's time is 'WAYYYYYyyyyy better spent on Python IMO) the better. I'm not sure why we have to keep beating THAT drum. The more hooks scripters have to use, the more they can bend the software to their own uses.
    Nov 2006
    4,576
    I believe what you described is very do-able. Your script would iterate through all the layers, and just turn off any layer that contained the string "-NV-".
    Profile piece
    2010 Reel
    'The X's' Reel
    Seattle
    14,739
    Well, that would be another function, part of the "assign unique names" function, really sort of the inverse. But it could be part of suite of "hidden layers" functions. Since I almost always only have one or two IMPORTANT layers, e.g. "Main" and "Eyes", turning them ON is usually trivial compared to turning OFF nineteen 'work layers'.
    I've rather garbled this up, so to recap:
    1) to use YOUR system, Nick, an "auto-namer" would be desirable to avoid the labor of naming layers when it's not all that important for documentation purposes, ie. only uniqueness matters
    2) for my workflow, adding "-NV-" to already Hidden layers would be desirable, and
    3) "Auto-hiding" layers with "-NV-" in their Layer name would also be desirable.
