Thread: SSS + Transparency
    Apr 2006
    Melbourne, Australia
    287
    SSS + Transparency
    Is there any special formula for making part of a Simple Skin surface transparent? I've tried mixing materials but the whole object wants to remain opaque.
    Failing that, using SSS 2 is there any way to control Distance, Backward Amount or any of the other parameters with a gradient? I just get a hard step no matter what.
    Thanks,
    (c:
    aka BRYPHI77
    Aug 2013
    worldspot
    71
    Quote Originally Posted by Chris Jones View Post
    Thanks,
    (c:
    Hi Chirs, here is quick test I put together using material mixer, seems to be working as expected. Also, if you plan on animating this object make sure you use one of the SSS nodes that does not use a preprocess, but uses samples instead.
    Attached Files Attached Files
    Apr 2006
    287
    Thanks tbagger, that's what I'm after - except that it transitions through black... know of any way around that?
    aka BRYPHI77
    Aug 2013
    worldspot
    71
    Tuning on double sided makes it go away... if it doesn't mess up the rest of your surface.
    Apr 2006
    287
    Double sided doesn't make any difference here. Another LW version discrepancy?
    Apr 2006
    287
    Forgot to mention, double sided wouldn't work on your test scene for some reason, but it did elsewhere. Go figure!
    Thanks again,
    (c:
