Results 1 to 8 of 8
Thread: Multishift issue?
    Pyshco 3d Artist - IT
    Wichita, Kansas
    165
    Multishift issue?
    Just upgraded to 11.5.1 and was doing some basic modeling when I noticed that Mutlishift picked up a strange new behavior. While working on a single poly in a new layer, mutlishift procedes to aply the shift to all background layers from where the orginal object was. i.e I copied a potion of another opbject in the model so I could keep the same contour to make the two objects look like they are mated together.
    If I apply the mutlhsift to the new object, the feature applies the shift to the old object in the background. Even when it is not visible. See screenshot. Is this something new and can I turn it off? Its making me backtrack through the model to fix the errant shifts. Making it take longer to finish said model.
Name:	Multishift issue.jpg
    When you have done it right, poeple are unsure that you have done anything at all.
    Oct 2012
    Japan
    6
    I don't have an answer regarding 11.5.1 but there is a Pre-11.6 available. Your problem could have been fixed in that release.
    Yep, upgrade to 11.6, as they fixed this bug.
    Wichita, Kansas
    165
    Well I would get the 11.6 upgrade, but the Newtek website is only showing me the 11.5 upgrade option. May be missing something here.
    South Yorkshire, England
    2,503
    Quote Originally Posted by jutland View Post
    If you login to your Lightwave3d.com account you should see it at the top of the registered products page.
    Registered User GoatDude's Avatar
    Aug 2012
    Atlanta, GA
    92
    I too started having this same problem. Good to know that it's a known bug
    Aug 2012
    Atlanta, GA
    92
    I ran into this also. It really screwed up a model I was working on since I didn't realize what was happening at the time.
