Page 2 of 15 FirstFirst 123412 ... LastLast
Results 16 to 30 of 214
Thread: Human Progress
  1. #16
    Nottingham UK
    2,757
    Stunning result though despite the pain
    Brilliant how you're pushing the software to produce these hyper real animations. Have you reported these issues to the dev team? Looking forward to updates.
  2. #17
    Not doing nothing.... Tranimatronic's Avatar
    Dec 2003
    Vancouver BC
    496
    Apologies if I am completely out to lunch here, and this bears no relevance on what you are doing, but for transparency in the simpleSkin shader, if you supply a subdermis depth where the depth is greater than the depth of the geo, you get translucency. I think if you keep going with it you will get transparency. I was going to try this on a jellyfish, but never got around to it.
    Basically run a (black=no depth, white=really deep) texture through DP's remap for your subdermis depth. Keep increasing the +ve scale and you will get translucent. Keep going for transparent. If I have time I will give it a go tonight & post the results.
    Cheers
    T
  3. #18
    Progress for sure Thanks for keep sharing these milestones of yours Chris.
    One question about the eyeball. I presume the Sclera (white part) has SSS. There were moments where I felt the surface was faceted, not smoothed. Now this could be because of two things. Skin shader is faceting, as I have seen happening (maybe mostly on double sided), or the youtube video compression is the culprit. Anyway the sensation is quite mild. I was just curious what was causing it.
    Also some "striping" in the back of the eye, on top, at the start and end of the video. Surely these are parts of the model one won't see in your project. Just curious.
    Cheers.
  4. #19
    Problems, and all, seem to make for some stunning work.
    Amazing.
  5. #20
    Apr 2006
    Melbourne, Australia
    287
    Thanks everyone!
    Quote Originally Posted by bobakabob View Post
    Not as such - I can't be certain it's not user error so I was hoping for confirmation first. Plus, I find the process of reporting a bit draining... so hopefully someone from dev will pop in here and save me the trouble
    Quote Originally Posted by Tranimatronic View Post
    Cheers
    T
    Not out to lunch at all, although I have some doubts about whether it will work in this case, considering the object is basically a sphere with an inverted refractive shape inside it, with the geometry overlapping at the cornea. Could be worth looking into though.
    I think the faceting you're seeing is YouTube's interpretation of the the finer veins in the bump map. The "striping" is due to the UVs being squashed up towards the back to give the front as much res as possible, along with me being careless with the detailing back there. As you say, it won't be visible (unless I need to pop an eye out of a socket, in which case I'll have to go back and do it properly...).
    (c:
  6. #21
  7. #22
    Dec 2003
    Vancouver BC
    496
    the idea in my post above didn't work. I can get it translucent, but not transparent. Also you don't get much control. I thought you may be able to fine tune the translucent feel by moving the subdermal depth (having a big gap between epidermal depth and subdermal) but in the end it just starts to look muddy and blobby, which I guess is exactly what you were trying to avoid.
    Also my test render crashed, so I have nothing to show. Ill have another pass at it tonight, but I dont think the idea is going to work. Oh well
  8. #23
    Lovely iris sculpt Chris, a pity it was of no use (not even to generate a normal map?). I bet you found those super hi res photographs of human eyes on the net, where you basically realize the iris is a ring of naked tendons stretching towards the pupil. Not a window on the soul at all but a sphincter really.
  9. #24
    Apr 2006
    287
    Could do... but I suspect that won't take bumps into account.
    Thought that might be the case, thanks for trying though.
    Quote Originally Posted by djwaterman View Post
    Yeah in macro it looks pretty gnarly when you shine a bright light across it... http://www.dailymail.co.uk/sciencete...ose-shots.html Realistically I don't need that level of detail though, it was more just for this demo. I generated a displacement and made a more detailed colour/bump map, but without SSS my first rough attempt just seemed to work better.
  10. #25
    Quote Originally Posted by Chris Jones View Post
    afaik, it should, at least the first one, as it only uses an illuminosity channel trick.
    (though can't guarantee it...)
    edit: Chanlum should work too...
    http://forums.cgsociety.org/showpost...&postcount=181
  11. #26
    England
    5,836
    Following your work like a hawk! Finding it all massively inspiring, as always!!! Nice to see such awesome results, and I'm sure the pain isn't purely down to LightWave's deficiencies... when you're pushing the boundaries of photo-realism, most software seems to push back quite hard!
    Great to see your techniques, and very nice of you to share nodal setups etc!
    Tim
    Desk Work:
    Desk Home:
  12. #27
    Sep 2006
    Future Past Life
    1,899
    Chris, what did you do for the transition from sclera to cornea?
    Nice work on the blood vessels. Those are always tricky.
  13. #28
    Apr 2006
    287
    I'm still having flickering issues with Sigma 2, so I might look into those when I revisit. Even getting any of the "real" SSS shaders to behave close to correctly was a bit of a strain though, so you'll have to forgive my skepticism.
    Well I hold LW fully accountable for my misery! But yes, I have to keep reminding myself that switching to software X would most likely unveil a plethora of all new roadblocks.
    Quote Originally Posted by BigHache View Post
    Basically a gradient on Z Coordinate blending Sigma 2 into Dielectric, based on tbagger's solution. Here's a snapshot of the nodes (I don't think that Fresnel is doing anything useful..).
    Oh, almost forgot - feature request: get Sigma 2 working with VPR (and the rest of the shaders for that matter). I'm back to F9 previews for most of this. :\
  14. #29
  15. #30
