Results 1 to 15 of 26
Thread: Speed Modeling Challenge #230- It takes Skills
    Rules:
    1.Every week there will be a subject for you to model along with a time limit. You should spend no longer than the allocated time, then post a render of your model. As in most challenges like this, your honesty on modeling times is essential. How you interpret the brief is up to you as long as the final model conforms to what is asked for.
    2.Post a wire-frame and a render at 800x600 or larger. (For wireframe help go to: http://www.artssphere.com/plugins/polygoncoloring.php)
    3.LightWave must be used for modeling. 3rd party Plug-ins are allowed.
    4.You can enter as many times as you like, posting each in this thread. If you run over the time, the model can still be posted but won't be subject to the judging.
    5.Time spent on texturing, setting up a scene for a render and rendering is not included in the allocated period.
    6.The winner is judged by the challenge starter and the prize is to set up the challenge after next week's.
    This week's topic: It takes Skills
    Any object that takes some type of skill to utilize. Something that just can't be picked up by anyone and used properly or effectively without some type of experience. I will leave it open for interpretation instead of suggesting ideas.
    Modeling time 120 minutes
    Deadline: Wednesday August 28th, 2013 22:00 EST
    Super Member PixelDust's Avatar
    West Virginia
    390
    This definitely needs skills to operate...
Name:	Scalpel Wires.png
    LW 11.6 - Modeled in 23 minutes, textured in 58 minutes.
    South Yorkshire, England
    2,500
    Interesting subject Steve. I hope to have some time to enter this one.
    \\ is sparkling // Iain's Avatar
    Jun 2006
    Edinburgh
    4,441
    Yes that certainly meets the brief, Pixeldust
    portfolio
    The Liver is evil and must be punished!
    Jun 2006
    Edinburgh
    4,441
    Something I have no skills with.
    An old model I did following some tutorial (one of William's maybe?), so disqualified.................
    portfolio
    Jun 2013
    Pandora
    74
    I think this one also needs some skills modeling 27 mins. Texturing way longer :P the grass was done with the dp grass plugin Click image for larger version.
Name:	lightwave logo copy.jpg
ID:	116562Click image for larger version.
Name:	lightwave logowireframe copy.jpg
    West Virginia
    390
    That's good for 27 minutes, James!
    Super Member akaracquel's Avatar
    Jul 2011
    Where The Wombats Live
    317
    Blog Entries
    1
    I went for paper [origami] because I've folded close to 3000 paper cranes in this lifetime ...but epically failed to make ONE in LW!
    I couldn't make it work starting off with a flat plane. No luck with bones in layout. Is there a way to group/ungroup polys?
    Here's the LINK to the *.lwo file of my attempt to draw up the unfolded polys (not precision accurate) ...in case anyone might want to try folding one
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,615
    Quote Originally Posted by akaracquel View Post
    Under the Detail Tab -> Create Parts. That's half of it. I don't know how to clear a part, though, short of reassigning a part's polygon's to another part...
    My Scripts for Lightwave
    Jul 2011
    317
    Blog Entries
    1
    hmm.. making a bit more progress from a flat plane today, made me realise there's extra folds missing in the *.lwo file above.
    Getting my head around Create Parts for tommoz, Thanks Kryslin.
    it's a manhole cover ↓ JoePoe's Avatar
    Jun 2006
    LISA
    1,969
    Truly a paper AND MIND bending rabbit hole!
    From a flat plane!!?? Are you folding sections completely flat?
    If so, doesn't that sorta defeat the purpose... you wont have the dimension of the actual folded piece.
    If you aren't folding completely flat, starting with the first compound fold (folding in a section that already is part of a fold) you're going to end up with some serious plane intersection problems. In order to avoid that, bends will have to have allowances built in to enable them to go around edges.... your flat plane just got incredibly more complex.
    I can see a build as you go approach possibly working (i.e. extending edges or adding poly sections as you need them), or, of course, model the final state.
    But from a flat plane? I will be patiently awaiting your tutorial at the bottom of the rabbit hole, wide awake from many sleepless nights (thank you very much ) .
    ... from a flat plane... from a flat plane... from a flat plane... from a flat plane... from a flat plane...
    Sorry for the small hijack.
    System Specs: A pile of sand, a couple of wires, a real live mouse and a beer.
    Feb 2009
    Prescott, IA
    1,615
    Well, Axis Rotate should let you rotate sections along the lines, and create part should allow you to group polygons (which you can select from in the statistics panels...)
    It'll be interesting.
    I need to hit the-blueprints.com for my reference for my idea...
    Jul 2011
    317
    Blog Entries
    1
    Quote Originally Posted by JoePoe View Post
    ...i know ...i know ...i know
    lol ...poly's started screaming "KISS!!!!!" when I tried... Will probably need to use digital calipers to nail it properly
    Finally ...something half-plausible & within time Not perfect, managed to tackle all the folds today ..but it's just a double-sided flat plane (no thickness added) and I haven't been able to tackle the extra allowances needed for edge-folds etc ..yet Didn't fold completely flat to 180 degrees, points were moved around manually.
    <sings> Chocolate CRANE! Some stay dry while others feel the {{PAIN!}} </sings>
    Will post screen capture later on in the week
    Aug 2010
    Kernow
    2,094
    Good effort there akaracquel, but I can't help think it would be easier to model the finished crane, rather than all the bending?
    Here's mine. You need mad skillz for this :-
    Jul 2011
    317
    Blog Entries
    1
    Quote Originally Posted by XswampyX View Post
    Reverse engineer a crane?! Do it …backwards?! Name:  ono.gif
Size:  1.5 KB No Way! ...but maybe I think it would be more difficult than winning a game of Ring Ross atm …but you can ask me again in 8 years time, after I've folded x1000 of them in LW!
    Link to sped up screen capture here.
