Results 1 to 15 of 22
Thread: Attention archvis guys - the ray cast node is your friend.
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,923
    I've been messing around with the new ray cast node in 11.6 and I have discovered that it is very handy for placing items from my vast library of decorative home accessories onto tables and other furniture. I sure hate those floating accessories and this does the trick.
    NewTek Developer jameswillmott's Avatar
    Dec 2004
    Gold Coast
    3,171
    Should be handy for placing plants in landscaped areas too.
    LightWave3D training, assets, news and discussion at www.liberty3d.com
    My opinions are my own and do not represent the opinions of any other entity, Liberty3D is not officially endorsed by NewTek.
    I will have to investigate that since I'm in the process of doing some production tests for having Lightwave do most of my rendering again.
    Super Member geo_n's Avatar
    jpn
    4,677
    Raycast node is pretty awesome. Many pracital uses.
    Yes it's handy but be sure you don't use it too often and then wonder why did scene slowdown . But good work DEVs, thanks.
    RAM-Studio
    Super Member OlaHaldor's Avatar
    May 2008
    Norway
    998
    Sounds interesting. However, I can't get Raycaster to work at all. Even the simple ground plane and sphere as demoed by Deuce at Siggraph isn't working for me. Yet the demo scenes work.
    3D Generalist
    Threadripper 2920x, 128GB, RTX 2080 Ti, Windows 10
    South Yorkshire, England
    2,500
    Quote Originally Posted by OlaHaldor View Post
    Make sure you move your geometry high above the plane before using the node. I found that if it was too close it didn't work correctly (some of the geometry was under the plane). Make sure your geometry is F3'd in Modeler (so lowest point is at 0,0,0) that helped me too.
    May 2008
    Norway
    998
    Yep, all is correct.
    I loaded the camshaft demo scene that comes with the new 11.6 content. Works fine! And I see no magic stuff going on except for the Raycast node.
    I clear the scene, load the camshaft object and apply Raycast, exactly how it was done in the demo scene. All is dead. Nothing happens.
    3D Generalist
    Are you sure you're using 11.6? clean install?
    555Lab.com
    HP Z800 Win 7 x64
    LW11.0.3 x64
    Bi-Quad Xeon E5530 2.40 GHZ
    16 cores Hyperthreaded
    20GB Ram
    Nvidia Quadro FX 4800 1.5GB / CUDA 192 cores
    Dual screen HP LP2475w
    Did you Doubleclicked on raycast node and told it which object to raycast to ?
    RAM-Studio
    May 2008
    Norway
    998
    I recorded a video just to be clear what I'm doing (and perhaps should be doing instead).
    Clean install. Absolutely positive it's 11.6, as you can see in the title bar on the video.
    It's still being processed, so it should be available in 1080p soon if you can't stand 720p.
    As you can see, the demo scene works without a problem. Even with other objects than the one's that came with the demo scene. (Why shouldn't it, right?)
    However, going with a clean scene - no matter what object or how I set things up, nothing happens.
    Perhaps a mod could split this topic and create a new one for my issues. Didn't mean to hijack your thread, Snosrap!
    3D Generalist
    Pessac
    5,072
    Try just connecting the Ray Cast node to the NodalMotion Position input. Double click on the RayCast node to set the object to raycast to, but don't connect the Input node.
    B
    LightWave 3D Trial Edition
    May 2008
    Norway
    998
    I tried that prior to recording. Didn't change a thing.
    LW crashed on me, and I got it working on one scene, but not on the second. Is it recommended to restart LW between scenes with Raycast?
    3D Generalist
    Dec 2004
    Gold Coast
    3,171
    You may have a slightly older version that had some persistent data between sessions, that's been fixed already so the next update you get should be fine...
    As Ben says, don't connect the Input node's position up to the Raycast origin, the position is always in local space and usually you want to raycast in world space. The node is smart enough to figure out that you want to cast from the origin in the context of modifying motion.
    Not sure why it isn't working , if you save your scene and reload, does it work then?
    Aug 2004
    Ohio, USA
    4,923
    Yep, I noticed that as well. Seems kind of crashy too.
