Results 1 to 10 of 10
Thread: LW Glitches- random keyframes and weird geometry.
    Registered User SonicN2O's Avatar
    Aug 2010
    Chicago
    485
    LW has been giving me grief for quite some time. when I make an auto keyframe (like by moving an object), LW creates ANOTHER keyframe a half frame or so after it for no reason. Also, when the camera moves over geometry, random artifacts appear in openGL that make it look like a kaleidoscope. This isn't reflected in VPR or render, though.
    "'Sup, Djents?"
    iMac Quad Core i7
    24GB RAM 1600MHz
    GeForce GTX680MX 2GB
    Banned OnlineRender's Avatar
    Dec 2008
    Glasgow , Scotland , UK
    6,370
    it could be fractional key frames ... chances are you have hit the shortcut "3" in graph editor and switched it on.
    Ill ask ryan to post he knows more about this than myself
    Aug 2010
    Chicago
    485
    1. I don't have Fractional frames turned on,
    2. I didn't ask LW to make those keyframes. here's what I'm talking about:
Name:	Screen Shot 2013-08-04 at 1.55.19 PM.png
    "'Sup, Djents?"
    iMac Quad Core i7
    24GB RAM 1600MHz
    Nov 2003
    jersey
    5,792
    Th fractional keys thing was a bug... cant remember what version it crept in on, but it was fixed in a following one. As for the weird polys... thats nGons... and thats just an OGL limitation, nothing to do with LW (which is why it renders fine).
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    It is a bug I think has been fixed. However, what still lingers are that a few plugins that handle keyframing no longer work with latest versions of Lightwave.
    Pay attention to what 3rd party plugins you are using that do keyframing, and make certain that they do not create fractional keyframes. IE: Create Key +, while incredibly useful, is broken because it generates nothing but fractional keyframes as of LW 10+.
    Aside from that, it is best to try to record exactly what you were doing when the error occured. Also mention the version of Lightwave you are using.
    Aug 2010
    Chicago
    485
    LightWave 11.5
    "'Sup, Djents?"
    iMac Quad Core i7
    24GB RAM 1600MHz
    i noticed a simular glitch in 11.5 and the new 11.6 Actually several. And these happen without Fractional keys turned on. just to be clear.
    1st glitch happens when 'lets say' Auto keys are turned on and you move your camera (or any other item) a new keyframe is created nudged after the original keyframe creating a pop in action, in the timeline it looks like one keyframe, but when zooming in on the key in the graph editor you see both keyframes on the same frame. Restarting LW often fixes it, but it does eventually come back.
    the 2nd glitch is basically the same but instead of a new key being created on the same frame its created on the frame either before or after the frame that your on.
    The last glitch in 11.6 .. Make Joint chain crashes LW.
    Make joint chain is found under utilities. very usefull.
    San Jose, CA
    6,774
    Please make sure to report these bugs via FogBugz, so the developers are notified of them and can fix them.
    There does appear to be a significant upswing of issues in previously-working tools and functional areas in 11.5 onward. I really hope LW3DG QA has taken notice, and is substantially beefing up (ideally, automated) regression testing to try and catch such issues before release.
    John W.
    underdog SaturnX's Avatar
    Oct 2003
    Northern Ireland
    465
    Quote Originally Posted by SonicN2O View Post
    A useful option aswell is to 'Snap keys'
    This will snap keys to one solid frame (non-fractional)
    You can access snap to key by right clicking on a key, in the dopetrack.
    Or you can do it via the graph editor.
    "Believe in your character. Animate (or write) with sincerity."
    — Glen Keane
    Kansas City
    43
    for what it's worth,if all else fails, try making a new camera. Make sure you're rendering with your new cam, then try autokeying whatever object you're moving. That seemed to fix it for me
    Be Good
