Results 1 to 8 of 8
Thread: Hypervoxel & Transpaent Objet Problem need help?
    Newbie Member alkart2003's Avatar
    Sep 2005
    Kingsport,TN
    74
    I have a plane with a texture and a transparent map applied to it but when I add a Hypevoxel for added gas cloud look the transparent areas show up. What can I do to fix this? Raytrace Trans is turned on and ray recursion is turned to 8 but still nothing.
    Registered User Trinnian_2's Avatar
    Mar 2013
    Germany
    11
    Is your refraction index for the plane set to 1.0?
    Sep 2005
    Kingsport,TN
    74
    Yes
    Mar 2013
    Germany
    11
    here is a testscene, maybe it helps...
    Attached Files Attached Files
    Sep 2005
    Kingsport,TN
    74
    I noticed you were using a volmetric light instead of a Hypervoxel. I need it to appear more like a slightly falttened sphere instead of a perfect sphere thats why I used a hypervoxel to use the Y strech direction. Is there a way to flatten out a volumetric light? Using hypervoxels gives my transparent texture map black areas where it should be transparent.
    Mar 2006
    Delta Quadrant
    221
    I actually JUST had this problem as well, I got around it by adding a black and white alpha image matte to the clip map of plane object properties.
    16,200
    you could try and add a previous layer gradient over the image in the transparency channel.
    MICHAEL
    16,200
    Sorry that won´t work.
    clip map gradient perhaps.
    or process the image in photoshop and make it a png with transparency perhaps.
    Michael
