Thread: BANDGLUE Option Not Found
    Jul 2013
    Florida
    1
    Hello
    I am using LightWave 10.0 and I know the Band Glue option is usually located in CONSTRUCT > REDUCE > MORE > BandGlue but it is not located there. Is there anywhere it it can be located or do I have to install the plugin? If I need to install, how would I go about doing so? Any help is greatly appreciated.
    Thank You
    7,898
    SwiftEdgeLoop is quite powerful alternative. It merges dissolve edge, dissolve edge loop, split edge, and split edge loop, with sliding edge loop
    http://www2.trueart.pl/?URIType=Dire.../SwiftEdgeLoop
    Dec 2010
    The Woodlands, TX
    60
    Go to Utilities Tab > Plugins > Edit Plugins. Then click Scan Directory and select your plugins folder in the Newtek directory where you installed LightWave, C:\...\Newtek\LW10.x\support\plugins. Click OK.
    Windows 7x64, Pentium Quad Core 2.50GHz, ATI Radeon HD 5750, 8 GB RAM
    Perpetual Newbie
    US
    238
    I had a problem with bandglue removing itself entirely from the hard drive; it still does this on occasion, for no known reason. If that happens to you, the only solution that worked for me was running the install wizard right on top of the existing installation. If you do that, you shouldn't lose your other plug-ins, but will probably have to remap custom hot keys. It's a pain.
    Swiftedgeloop looks interesting.
    Professional amateur Amurrell's Avatar
    Dec 2005
    Lincoln, NE
    1,350
    Go to the edit menu dialogue and search for it. It's under a "more" tab.
    --Andrew
    Bono Animo Esto
    Intel Core i5 3570k
    nVidia GTX 970
    8GB DDR3 1333MHz
    Windows 10 Pro 64bit
