Results 1 to 15 of 26
Thread: Mac Freezes when freezing sud-D mesh at render
    Not So Newbie Member
    Oct 2008
    Melbourne, Australia
    25
    Hi there,
    I'm hoping somebody knows a solution to this issue because it's really annoying.
    I created a moderately high poly Sub-D sphere in modeler then sent to layout to add a honeycomb texture as displacement map to get the attached image here.
    I set render subdivision level to 30 and my mac can't handle it, seems as though it goes into an infinite loop!!
    However my cheap little PC freezes the mesh in 2 seconds...
    Any Mac LW'ers have this issue before???
    cheers
    G
    Vacant, pretty vacant pinkmouse's Avatar
    South Yorkshire
    1,712
    Can you post the scene so we can try it?
    Aug 2006
    S
    3,511
    Render Subdivision Levels isn't the same thing as freezing the mesh in Modeler. When you import a subpatched object into Layout the subds are automatically "frozen". You can see this if you save out a morphed or dynamics Layout object back to LWM. I doubt your cheap PC would render 30 subD levels in Layout...
    You mean surface displacement? Then your moderately high poly sphere will do, you just need to UV it so the honeycomb image works then turn the same image into a displacement and normal map.
    - "Textured Displacement" in the object's properties pane under Deform, actually deforms the mesh via a texture map.
    Aug 2006
    S
    3,511
    If you wanted to model the honeycomb just for the sake of it use Multiply/Rounder on a tesselated sphere set so you can select the new surface and bevel/smooth shift.
    Attachment 115103
    at 30 levels of subdivision its running out of memory and writing packets to disk hence the sense of looping, even in 64bit mode (you are in 64bit mode I presume) six levels of subdivision is about as high as I can go even with a ton of memory installed. Lightwave does not do micropolly displacement as far as I know and the adaptive subdivision setting which would help never seems to work properly, so the combo as stated above of a a uv map to support a much lower level of displacement and a normal map and bump map would be way better
    Aug 2006
    S
    3,511
    It's not just running out of memory it's a completely hypothetical number beyond about 6 as you say. Apps like ZBrush can handle gazillions of surface subdivisions because they only deal with essentailly an isometric prophection. No camera view which has to move around in space.
    just saying I have never got it above six with anything of more than average size in Lightwave, not other programs, Lightwave displacement performance has always been piss poor, original mesh density may be a factor he did say it was fairly dense
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,693
    If you're freezing an object in Modeler then you need to check in Options how many it will freeze
    1 = as you see it
    2 = double
    etc
    TIP: If you want to bring a subpatched object into Layout and adjust the layout levels of display.
    1. Add a NULL to layout first
    2. Set the levels of display of the NULL to 0, or 1, or 2 etc (and the render levels too if needs be)
    3. Replace the NULL with your object
    That way the object won't come in to Layout at a high level and you can adjust it's display level in Layout.
    Hope it helps
    Oct 2008
    25
    Hi all thanks for the replies.
    I believe I may not have explained myself accurately enough... So here are some images and scene files to clear up what I mean.
    These are taken from my PC screen capture and like I said the process takes 2 seconds when "render subpatch" level is set to 35. Whereas the Mac can't even do above 6. It crashes completely and I have to do a restart.Click image for larger version.
ID:	115104Click image for larger version.
ID:	115105Click image for larger version.
    Scene and object files are below, I omitted the texture image because it is 32mb. Also ignore the hollywood object request and the palm object.
    cheers fellas
    https://www.dropbox.com/l/cmY0pcMw3i1sTzMAJilUYa
    Aug 2006
    S
    3,511
    me neither but 30 RSL definitely doesn't work here even with a basic subd cube. I don't think it's supposed to either... I thought once that the nuumber of points in a curve allowable in LW would increase from 256 to 512 with 64 bits.
    Oct 2008
    25
    Adaptive subdivision is what I'm after
    Oct 2008
    25
    william vaughan did a tutorial a long time ago where he used the APS (adaptive subdivision level) at 40 to create the illusion of fur
    Oct 2008
    25
    Quote Originally Posted by meshpig View Post
    Mate that's a great idea, works well
    Aug 2006
    S
    3,511
    Quote Originally Posted by Grazby View Post
    Yes well with "textured displacement" you're entering the world of Voxel modelling. Some people like it others don't. it's like the Pottery department at Fart school. Dynamesh in ZBrush though...
    it's a manhole cover ↓ JoePoe's Avatar
    Jun 2006
    LISA
    1,969
    Hmmmmmm, to me, something is wrong.
    I am regularly (well, sometimes) well up in render subD levels near 100. Of course it's always dependent on the density of the original mesh.
    Which brings us to your actual problem. I could process it no problem (see attached....your object > render subD at 50).
    AND, I have to mention... the system specs in my tag line are not that much of an exaggeration. I'm on a seven year old pre Intel Mac Power PC quad with 4 gigs Ram.
    Oh, the freezing took about a minute.
    If I can do it...........
    Edit: fyi, @ 50 subD poly count was 2,450,000.
    System Specs: A pile of sand, a couple of wires, a real live mouse and a beer.
