Thread: Modes: Action Center Control, Missing
    Feb 2006
    santa monica
    238
    LW 11.5 I don't see the Modes: Action Center Control it is missing would you please help me to find it
    Quote Originally Posted by simonlion View Post
    With the default installation, they should be at the bottom (where point/edge/poly mode used to be.) but you can put them anywhere.
    Feb 2006
    santa monica
    238
    If I can not find it Inside the Edit Menu Layout, then I can select it for my bottom menu, but where is It Inside Edit Menu Layout
    Alt f10, click on "search", type "Action Center"
    Pessac
    5,192
    I wrote a page for you. The layout needs fixing: http://lightwiki.com/wiki/Getting_buttons_back
    B
    LightWave 3D Trial Edition
    San Jose, CA
    6,957
    Ben, this brings up a key problem with LW menu layouts: There's no way to easily wholesale save/edit the various "default layouts" because the menu editor refuses to save entire default layouts to a file, it yields an empty file more or less. Can someone please fix the menu editor so that it is capable of saving out the entire definition for default layouts? I filed a bug on this ages ago, and these kinds of situations are the perfect example of why such functionality is needed.
    John W.
