Thread: Undo Dose not work on Multishift
    Feb 2006
    santa monica
    238
    I created an object and when I use Multishift, Later If I use Control-Z or File-Undo, it dose not undo it. I noticed Undo dose not work on some other matters in the past.
    would you please let me know
    Thank you very much.
    It should undo with the entire operation but not for shifts within the operation. For that the only control I am aware of is in the Numeric panel where you can cycle through the shifts and insert/edit or delete them,
    3D Junkie Serling's Avatar
    Jan 2008
    Walled Lake, MI
    780
    Quote Originally Posted by simonlion View Post
    Drop the tool, undo, then use the tool again if you get totally stuck.
    Six-time Emmy award-winning news and special projects editor.
    http://www.myfoxdetroit.com/story/20...years-at-fox-2
    Feb 2006
    santa monica
    238
    I unchecked the Multishift and then I did undo and now It woks
    Thank you very much..
