Thread: Single-shot Python script to set content directory and custom paths in Layout
    Red Mage Celshader's Avatar
    Burbank, California
    1,817
    An artist asked if it was possible to use LWPython to set both the content directory and custom paths in Layout and Modeler. I am not yet sure about Modeler, but I have a single-shot script that sets custom paths in Layout.
    In this script, LWPython sets the Layout content directory to "C:\Temp\Content", the default Objects directory to "Meshes," and the default Images directory to "Plates."
    Code:
    import lwsdk, os
    ## this version places all of the variables up here for easier editing.
    contentDir = "C:\\Temp\\Content"
    objectsDir = os.path.join(contentDir, "Meshes")
    imagesDir = os.path.join(contentDir, "Plates")
    ## single-shot formatting:
    ga = lwsdk.GenericAccess()
    ## turn off "Use custom paths" to "clean out" the old custom directories
    ga.evaluate("UseCustomPaths 0")
    ## change the Content Directory.
    ga.evaluate("ContentDirectory " + contentDir)
    ## turn on "Use custom paths" to enable fresh, new custom directories
    ga.evaluate("UseCustomPaths 1")
    ## change only those directories that you like. The rest will remain at LW defaults.
    ga.evaluate("ContentTypeDirectory Objects " + objectsDir)
    ga.evaluate("ContentTypeDirectory Images " + imagesDir)
    ## tell the user what you've done.
    title = "Done."
    message = "Changed content directory to: " + contentDir
    mf = lwsdk.LWMessageFuncs()
    mf.info( title, message )
    Jen's 3D -- LightWave stuff.
    Jen's 2D -- my comic book.
    Python is my smashing board. LightWave is my S.M.A.K.
    Nov 2006
    Burbank, California USA
    4,576
    Very cool!
    Profile piece
    2010 Reel
    'The X's' Reel
    Sep 2006
    Future Past Life
    1,899
    Thanks Jen.
    Jen did you ever figure out a way to do this in modeler? I have been banging my head against it as of late.
    thanks
    also for anyone that uses Generation, This will connect to generation and get the open project and change your content directory to it. I'm trying to do the same for modeler but haven't figured out the correct command, maybe even put it as a startup command so as you startup, it will see if generation is running and just set it for you. of course change to match your file structure, and tab in the if statement.
    import lwsdk, os
    import sys
    sys.path.append('c:\\Python27\\Lib\\site-packages')
    import PeyeonScript as eyeon
    gen = eyeon.scriptapp("Generation")
    if gen != None:
    proj = gen.ProjectGet()
    projectName = proj.Path
    contentDir = projectName + "LW\\"
    lwsdk.command("ContentDirectory " + contentDir)
    illuminatedtools.com My great light probe Library.
