Thread: Codecs Tricaster XD300
    Jan 2010
    NA
    3
    Hi
    I am renting a Tricaster XD300 and am trying to export from Premiere suitable HD videos for playback from the Tricaster. So far the MPEG2 and H.264 don't seem to work, can someone point me in the right direction?
    thanks
    Paul
    Dec 2009
    Columbus, NE
    129
    I have a 300 and use CS5.5. and have never had an issue. The original files I use typically are HDV files from a Canon XHA1 and the videos are exported as mpeg2 files at HDTV 1080p 29.97 high qual playback. 1440 x 1080i 29.97 has also worked flawlessly.
    19,649
    Keep in mind TriCaster 300 records two types of MPEG-2 files. As I recall, only one of them (forget which, sorry) was supported by Premiere.
    Jan 2010
    NA
    3
    Thanks for the replies. I found that the Quicktime using H264 worked, as well as DVCProHD (but really huge file size)
    I will also be recording externally so if the tricaster record doesn't work I have a backup.
