Results 1 to 8 of 8
Thread: Placing object on a surface HELP NEEDED
    Registered User Remoc's Avatar
    Feb 2008
    Darwin Australia
    126
    Hello Lightwavers,
    How can I place objects onto a surface.
    I have included a picture to show what I want to achieve.
    I want the diamonds to go all the way around the beveled text in two neat rows. ( or maybe three )
    I need the diamond tops to face outwards along the surface normals.
    Thanks in advance,
    Remoc
    Ninja Troll phillydee's Avatar
    Jan 2006
    alucemeT
    308
    What about using 11.5's new Modeler tool, "Place Mesh"?
    http://www.youtube.com/watch?feature...QsVe0n4#t=128s
    (around the 2-minute mark)
    In Modeler, go Multiply tab > "Place Mesh" (located within the "Duplicate" group)
    Quote Originally Posted by phillydee View Post
    I almost suggested place mesh except that populate won't work because it seems to work per polygon and he has many polys on the curved letters but only a single polygon on flat areas so it would not disperse them correctly. He could place them manually, but without any kind of snapping or placement assistance, he wouldn't be able to disperse them in neat rows like he wants. It would help if place mesh allowed you to slide an object over the surface of an object before deciding on final placement.
    skeptic lertola2's Avatar
    Dec 2008
    New York City
    1,117
    Make a spline curve for each of you letters and then use rail clone to copy your object along the spline.
    Jan 2006
    alucemeT
    308
    Wow that's a bit of a limitation...
    I thought of LW's Rail Clone, gave it a go but it clearly doesn't work for something like this...
    In the end, I used LWCAD's Rail Clone and this is the result after 2 minutes of dwaddling. Other than that, I'm not sure how you can get uniformed, ordered clones aligned to normals other than using something like LWCAD... this is the best I could do. I'm sure if I changed the curve origin it will line up a bit better but this is progress (I guess?)
    Hopefully the OP has LWCAD
    UPDATE--I bunged LW's RAIL CLONE as it can be done (as posted above)... anyway, I guess mine's more a secondary option
    Feb 2008
    Darwin Australia
    126
    curve rail clone
    I used " Make Closed Curve " from the inner points of the first letter V.
    However in my attached image it show the problem.
    Can I " tighten " the curves, to create straight lines and sharp corners?
    Thanks,
    Remco
    Use add points to tighten curves.
