Thread: In and Out transition?
    Dec 2007
    Germany
    173
    Hi!
    When switching to replay I want to use a custom made wipe.
    When switiching back I want to use another custom made wipe.
    Anyone an idea how to realize the switiching the most elegant way (= not changing transition manually)?
    Tricaster 8000 is used. As far as I can see unfortunately the macros don't record a selection of transition...
    Looking forward to your ideas! :-)
    Best regards,
    Matthias
    19,688
    Hmmm. I'm running a different build that you would be, which might account for it - but I am able to record macros that change the current transition.
    Once more into the CPU!
    Oct 2006
    Port Orchard, Washington
    441
    Might I just butt in and ask how to create a custom transition for a TriCaster system?
    TC Mini SDI 5-1-190425
    -BlackMagic Studio Cam
    -SDI cables
    -Spark SDI
    -LiveText w/SB2
    -YouTube Stream
    _
    SKTV 205
    https://www.youtube.com/user/SKHSVideoProduction
    19,688
    Assuming we are discussing a model that supports Animation Store Transitions, you do so using the Animation Store Creator application included with the TriCaster (also included in the optional VSE 2 'suite').
    Jan 2013
    Kennewick, Washington
    37
    Quote Originally Posted by matthias-web View Post
    Hi!
    Best regards,
    Matthias
    I have successfully macro'd transition selections. The thing to remember is what you actually record. From what I can tell, if you macro the selection in the little popout window of transitions, then the macro will activate that window.. doen't matter what transition is in it. Does that make sense? My morning news program uses one transition for the opening 'headlines' part of the show, a second transition for 95% of the rest of the show, and a third transition for a specific segment. So I can tell you that macroing transitions is possible.
    Hope that makes sense, let me know if I'm confusing you.. :P
    Joe Quigley
    KVEW-TV
    www.kvewtv.com
    System: TriCaster 8000 w/control surface and AVID audio surface
    GFX: Chyron IP
    Cameras: Panasonic AG-HPX370P (x3)
    Oct 2006
    441
    Where would that be on the TC40?
    -SDI cables
    -Spark SDI
    -LiveText w/SB2
    -YouTube Stream
    _
    SKTV 205
    Bloomington, IN
    1,631
    The TC40 is the model that doesn't support animation store transitions.
    -Jeff
    My TriCaster Blog
    TriCaster Tally Lights
