Thread: How do you get a sphere to look as good as this with fracture?
    Newbie Member Peter Ekberg's Avatar
    Mar 2006
    Sweden
    80
    Look at 4:50 in this vid http://www.youtube.com/watch?v=P8XqSv3hRPA
    how is this done? when I use fracture Im not able to get a smooth nice sphere..
    Would someone please be so kind to explain the steps
    BR Peter
    The cake is a lie....
    WS1 i7 [email protected]/6GB/Win7 64/470GTX
    OC to 4GHz and water cooled
    WS2 MacPro [email protected]/6GB/OSX
    I don't know if this will help, because I rendered these to show the wires so you can see the pre-fracture in the wires, but they weren't visible before using the shader and there was a switch in the bullet UI that seemed to keep the object from showing any cracks but I can't look at it right now to see what it was. However, probably the surest method would be to swap out the object with an un -fractured one and cut between them.
    Cow Orker cagey5's Avatar
    Manchester UK
    3,273
    It's really a matter of resolution. In the pictures attached the ball on the left is the default sphere settings of 24 x 12. The sphere on the right is 96 x 48. Smoothing is set the same for both objects.
ID:	113608   Click image for larger version.
    Forum Tips
    If English is your first language, you should know it's 'losing' and not 'loosing'!
    Mar 2006
    Sweden
    80
    Awesome looking but if you do this to say with glass balls? how would you solve fractures and smooth surface?
    Mar 2006
    Sweden
    80
    so both objects in the image to left is fractured right.
    the sphere to the right looks good but how would you solve a glass material?
    Manchester UK
    3,273
    Either switch objects at point of impact or keep internal surfaces at 100% transparency until point of impact might work.
    [EDIT] I seem to recall that the dielectric node could be useful in such cases, though I think cast shadows would always be a problem.
    Forum Tips
    I think the switch is the only way to solve a transparent object.
