Thread: green screen pipes...
    Jun 2005
    los angeles
    78
    Just in case I need to remove the B/G Click image for larger version.
Name:	pipes green.jpg
    Space Monkey 3DGFXStudios's Avatar
    Sep 2005
    Earth
    3,121
    What about using the alpha channel for that?
    Just save as a 32 bit targa, tiff or what ever you use and the alpha will be embedded. Don't use the green screen unless you are having a joke with us here.
    Jun 2005
    los angeles
    78
    No the green B/G is in case I need to take the image into Photoshop and remove the B/G layer for compositing...
    Sep 2005
    Earth
    3,121
    Are you kidding?
    Yes we understand but that not how you do that. You need to save your image in an 32bit format so you have an alpha. TGA32 or Tiff32 or exr. You can find the alpha channel in photoshop in the channels window. ctrl click on the alpha thumbnail and press delete to delete the background to get the photoshop transparency thing I think you are after. Making things green is NOT a way to do this.
    Jun 2005
    los angeles
    78
    Sorry...didnt mean to offend...
    Sorry I didn't mean to offend...coming from a video B/G I thought that would be the way to do it but I guess I'm wrong...
    Ha ha I remember doing the same at some point in the past when I started with 3D. It's actually legitimate technique but rather pointless when you can embed the alpha, also, if that was your plan you didn't light your Green screen evenly.
