Results 1 to 12 of 12
Thread: Bullet softbody melting
    CG Generalist akademus's Avatar
    Dubai, UAE
    1,606
    Hey everyone,
    I've been messing with this the whole morning now. My idea is to use bullet to pour icecream into the cone. However, I cannot seem to get upper part to pour down while retaining the base in more/less same shape.
    Anyone has an idea? I attached screen grab and lw project...
    Attached Files Attached Files
    Banned OnlineRender's Avatar
    Dec 2008
    Glasgow , Scotland , UK
    6,359
    did you assign weight map ?
    Dubai, UAE
    1,606
    Quote Originally Posted by OnlineRender View Post
    To what?
    I'm trying to solve it with distance to null in Shape Retention and Damping Coeficient but it doesn't seem to work.
    Sep 2005
    Earth
    3,121
    I tried something like that to. It looked to me like the weightmaps I created didn't work at all when assigned to the Shape Retention. The mesh filter isn't an option either since it doesn't respect the settings on the edges of the weightmap which is a really bad thing. I think the edges where the weight map stops working need to respect the stiffness settings. With the current implementation of the mesh filtering system you always get a sharp bending edge where the dynamics are "on/off". What you can do to fix this is make a mdd file and blend the mdd with the original mesh. This way you can have a weight map that really blends from 0 to 100. Mixing mdd would be an option to. If you like the simulation of the bottom part you can use that and blend them with a cool sim of the top part.
    Quite a shallange!
    Dubai, UAE
    1,606
    Quote Originally Posted by 3DGFXStudios View Post
    Dumb question, but how do you blend two mdds?
    EDIT: Found it http://forums.newtek.com/showthread....How-to-mix-MDD
    TD/Animator lino.grandi's Avatar
    Jun 2003
    Rome
    1,700
    You can find some Bullet Dynamics melting scenes in the 11.5 content.
    Lino Grandi
    3D Development, LightWave 3D Group/NewTek, Inc.
    https://www.lightwave3d.com/
    LightWave 3D Group YouTube channel:
    http://www.youtube.com/user/Official...?feature=watch
    My YouTube Channel:
    http://www.youtube.com/user/linograndi?feature=mhee
    Dubai, UAE
    1,606
    Thanks Lino,
    I already found chocolate ones. Very insightful.
    Mdd blending seems to work. Not the happiest of solutions but it works nonetheless.
    Dec 2008
    6,359
    hmm I cant seem to remove the gradient texturing on the shape retention
    Dubai, UAE
    1,606
    I noticed bullet wont refresh when you switch gradient on / off. You need to reset cache...
    Dec 2008
    6,359
    I got the top to drop but it just wobbled like jelly at the base , if I am honest I think bullet needs some more work
    Sep 2005
    Earth
    3,121
    Bullet needs a simple way to blend kinematic and soft dynamics. Shape retention and mesh filter ins't good for that.
    It also needs constraints springs and hinges.
    For now bullet is only suitable for dropping stuff (almost)
