Results 1 to 15 of 21
Thread: Get Layer number from Layout
    Nov 2006
    Burbank, California USA
    4,576
    ReplaceObjectLayer expects the layer number for the first argument. So how do I get that information from Layout?
    ReplaceObjectLayer(<layer number>,<filename>);
    Replace the current selected object layer with the layer chosen from the file.
    Profile piece
    2010 Reel
    'The X's' Reel
    Nov 2006
    4,576
    It looks like there's a solution in here:
    http://forums.newtek.com/showthread....l=1#post328292
    Seems inelegant but it works.
    Profile piece
    2010 Reel
    'The X's' Reel
    Animator / Artist Sculley's Avatar
    England
    159
    Welcome to try this...
    Code:
    getlayernumber: item
        if(item.totallayers == 1){return(1);}
        sTokens = parse(":",item.name);
        iLayer = 0;
        if (strleft(sTokens[2],5)=="Layer")
          iLayer = integer(sTokens[2]);
        else
          iTotal = item.totallayers;
          for(i = 1; i <= iTotal; i++)
            if(item.layerVisible(i) == 1)
              if(item.layerName(i) == sTokens[2])
                iLayer = i;
                break;
            else
              iTotal++;
      return iLayer;
    I use it in many of my scripts. For an example see http://www.teximitation.com/blog/lsc...ric_StackIt.ls
    Nov 2006
    4,576
    Thanks!
    Profile piece
    2010 Reel
    'The X's' Reel
    Here is a script I've made for this purpose, its made to work in any case, accept when two layers have the same name, so you should avoid this case
    Code:
    @version 2.3
    @script generic
    @name GetLayerNumber
    generic
    	curItem = Scene().getSelect(MESH);
    	if(curItem.count()>0){
    		info(getlayernum(curItem[1]));
    getlayernum: obj
    	if(obj.isNil() || obj.null) return nil;
    	layercount = obj.totallayers;
    	if(layercount>1){
    		layerindex = 1;
    		tmp = split(obj.filename);
    		nom = tmp[3];
    		testedlayers = 1;
    		found = false;
    		objCleanName = obj.name;
    		if(strright(objCleanName,1)==")"){
    			tmp = parse(" ",objCleanName);
    			tmp.pack();
    			tmp.trunc();
    			cloneNumberStr = tmp[sizeof(tmp)];
    			test = cloneNumberStr.indexOf('(');
    			cloneNumber = 0;
    			if(test){
    				cloneNumberStr = strsub(cloneNumberStr,test+1,sizeof(cloneNumber) - 2).asInt();
    			cloneNumber = cloneNumberStr.asInt();
    			if(cloneNumber.asStr()!=cloneNumberStr){
    			}else{
    				tmp[sizeof(tmp)]=nil;
    				tmp.pack();
    				tmp.trunc();
    				objCleanName = implode(" ",tmp);
    		while(testedlayers <= layercount)
    			if(obj.layerName(layerindex).isNil()){
    				layername = nom+":Layer"+layerindex.asStr();
    			}else{
    				layername = nom+":"+obj.layerName(layerindex);
    			if(layername == objCleanName){
    				found = true;
    				break;
    			layerindex++;
    			if(obj.layerVisible(layerindex)) testedlayers++;
    		if(found){
    			return layerindex;
    		}else{
    			return nil;
    	}else{
      		return nil;
    implode: sep,lst
    	txt="";
    	for(i=1;i<=sizeof(lst);i++){
    		txt = txt + lst[i].asStr();
    		if(i<sizeof(lst)) txt = txt + sep;
    	return txt;
    These workarounds are no longer needed since 11.5, you can now use the layerloaded method to get the current select object layer's number in Layout.
    selected = Scene().getSelect();
    layernumber = selected[1].layerloaded;
    Nov 2006
    4,576
    Ah very interesting, thanks.
    Profile piece
    2010 Reel
    'The X's' Reel
    Nov 2006
    4,576
    Quote Originally Posted by tajino View Post
    Tajino,
    Where did you find this information?
    Profile piece
    2010 Reel
    'The X's' Reel
    Axes grinder- Dongle #99
    Seattle
    14,740
    YES, that's a very good question: Where did you find this information?
    Praise to Buddha! #resist
    Heffalump
    Away
    3,897
    It seems to be mentioned in sdk/html/globals/objinfo.html, but not in the context of LScript...
    Inactive.
    Nov 2006
    4,576
    All I can say is thank jebus for the forum.
    Profile piece
    2010 Reel
    'The X's' Reel
    Seattle
    14,740
    Amen.
    - - - Updated - - -
    Quote Originally Posted by nickdigital View Post
    Tajino,
    I posted this as a feature request not knowing it already existed, got a quick reply from Area51 at newtek dot com about this has been implemented since 11.0.3 or 11.5 not quite sure.
    England
    159
    We should put in a request just to have a full list of all functions on the document so everyone knows what there are! The documents have become far too fragmented.
    San Antonio, Texas, USA
    13,057
    Tajino,
    From me, on a bug report asking to be able to do this, below is the sample code I gave.
    Looks like this command was added in 11.5
    Code:
    @version 2.2
    @warnings
    @name "Get Layer Number"
    generic
        // Get the first selected item
        (selectedItem) = Scene().getSelect();
        // Nothing selected?
        if(selectedItem == nil)
            info("No item selected");
            return;
        //  Get the ID of the selected item
        selectedItemID = selectedItem.id;
        // Get first object
        mesh = getfirstitem(MESH);
        // Scan through all valid objects
        while(mesh)
            // Skip Null objects
            if( (!mesh.null) )
                // Does it match what was selected?
                if( mesh.id == selectedItemID )
                    // Yes, so get the layer number
                    selectedLayerNumber = mesh.layerloaded;
            // Get the next mesh
            mesh = mesh.next();
        info("Selected Item Layer Number: ", selectedLayerNumber);
    UI / UX Designer @ NewTek
