Results 1 to 9 of 9
Thread: Scale to BG BoundingBox script/plugin?
    Registered User sami's Avatar
    TopLeft Viewport
    1,055
    Question Scale to BG BoundingBox script/plugin?
    I thought the Absolute Size did this, but I can't get it to work.
    Does anyone know of a one-click scale FG layer to the exact size of the BG layer's bounding box?
    thanks!
    Spinny Spinland's Avatar
    Apr 2005
    Utica NY, USA
    2,014
    Modify->Transform->More->Fit to Background?
    “There may be people that have more talent than you, but there’s no excuse for anyone to work harder than you do.” ~ Derek Jeter
    iMac Pro
    "iCan" Mac Pro
    MacBook Pro
    Multiple Mac Minis
    TopLeft Viewport
    1,055
    I tried a BUNCH of scaling plugins, but none did what I wanted except this one:
    http://www.lwplugindb.com/plugin/dimension/
    however, this one only works with a BG layer in the same object, you can't scale to a BG layer in another object so you have to cut and paste the BG object you want to another layer in the first object and make that BG before running this.
    TopLeft Viewport
    1,055
    Quote Originally Posted by Spinland View Post
    Ahh thanks that works too just like that plugin I mentioned (you need to have the BG layer in the same object for it to work) -
    I didn't see it initially because "Fit to Background" is not in 11.03 and is new in 11.5 -- I'm still working in 11.03 since I'm mid project and haven't fully set up or started using 11.5 until this project ends. Here's another good reason to start working day to day in 11.5 - it's just been our best practice to not change versions mid-project in case scenes or plugins or whatever get broken and we don't have time to chase up these things in the middle of production. But since they install side-by-side doing stuff like this is easy.
    thanks for pointing that Fit to BG out
    Axes grinder- Dongle #99
    Seattle
    14,741
    Quote Originally Posted by sami View Post
    I didn't see it initially because "Fit to Background" is not in 11.03 and is new in 11.5 -- ....
    R U sure about that (the newness)? I just did a Search on the 11.5 addendum on "fit to background" and got zero hits.
    (Actually, didn't find it in ANY of the relevent PDFs: but IMO Acrobat's Search is almost as lame as this forum's.)
    EDIT: in fact this 2006 link refers to FTB as "that old legacy plugin".
    http://forums.cgsociety.org/archive/.../t-406381.html
    Praise to Buddha! #resist
    TopLeft Viewport
    1,055
    It wasn't in my Modify > Trasform section in 11.03 - so in 11.03 I searched plugins and Edit Menu Layout and found nothing. In the default 11.5 install Fit to Background was there in Modify > Transform already. And since I don't remember that command ever, I assume it has to be new (given that it is not in 11.03 that I can find).
    If it is a legacy plugin, then I forgot about it and they took it out for 11.03
    Seattle
    14,741
    It was in my Studio configs-- I sure didn't add it myself. Which config version are you using? (You might prefer the Studio configs.)
    Anyway, it's been around since 2006, when it was 'old', so ixnay on the ewnay.
    TopLeft Viewport
    1,055
    What are the default configs that install with 11.03 then? That didn't have it. Am I supposed to search every config that ships? Clearly the default configs in 11.5 have it now.
    Seattle
    14,741
    There's only maybe two. It's right in the presets.
