Thread: Question : Luminious Polygons and reflections ????
    Michael Nicholson zapper1998's Avatar
    spokane washington usa
    4,663
    Blog Entries
    1
    U have a Luminosity Polygon as a Light source..
    In objects property panel u have unseen by camera.
    ok...
    So how does one keep that poygon from showing up in the reflections??
    Help needed
    Mike
    Intel Core i7-980, OC 4.7ghz water cooled.
    Gigabyte x58-UD3R with an Intell SSD 180GIG
    RamCorsair-DDR3-1600-32GIG
    Nvidia Titan Z, x 2 And 1 GTX-1080 by Gigabyte.
    4xEnterprise/WDVelociRaptorŪ300gig
    Nov 2003
    jersey
    5,792
    unseen by rays.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    8,067
    Or you can plug Spot Info > Bounces to Gradient then if it's 0 -> some value, >0 -> 0.0, plug output to Luminosity. So it'll work per surface, rather per item.
    San Jose, CA
    6,879
    Won't that still potentially be visible in reflections (as a "dark" shape) if in front of a lighter background/object? You could use the same approach to control visibility (via transparency/opacity/whatever) as well, though.
    John W.
    8,067
    Reflections should have Bounce > 0.
    So they should see them as without Luminosity plugged at all (original color of surface).
    8,067
    I was more thinking about luminous shape f.e. some object that is emitting light. But is also normally visible.
