Thread: 3play 425/820 Shortcut sheet
    Macro Titan JonRaidel's Avatar
    Sep 2009
    Los Angeles, CA
    216
    Im looking for the shortcut's that newtek implements with their new updates. in the manuals there are the basic shortcuts for the controller, but not anything new they implement. anyone have a clue where I can find these things?
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    Panasonic HDX 900 Cameras
    NDI Connect Pro
    Graphic Outfitters ScoreHD
    Graphic Outfitters Scorebridge
    Livetext 3 w/ LT [Scoreboards 2]
    19,375
    The list in the manual should be up to date. If there are omissions, it would be good to either mention them here or bug them.
    Sep 2009
    Los Angeles, CA
    216
    i wish you were correct sir. but the manuals dont get updated per Rev. ex. Rev5a to Rev5b doesnt get a new manual. at least not that i see
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    NDI Connect Pro
    19,375
    Well actually, manuals are updated in releases as required; actually even more frequently when need dictates, since the docs linked to QR codes in the UI (and available from the support site) are sometimes newer than the ones in current releases.
    As of this moment, there's only one CS/Shortcut related item listed to be added to 425/820 docs, as follows: "CS: EDIT + speed -> updates the preset speed of the currently selected playlist item." This doesn't mean nothing could ever slip by unnoticed, though, and undocumented features often aren't very useful, so if there seem to be any other omissions, we'd want to address them.
    Sep 2009
    Los Angeles, CA
    216
    thanks for the followup. the manual downloaded didnt give me that CS shortcut. and I feel like there were more added at somepoint...
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    NDI Connect Pro
    19,375
    I'll try to remember to double check this in the coming week.
