Page 43 of 43 FirstFirst ... 33414243
Results 631 to 639 of 639
Thread: 11.5's BenchmarkMarbles.lws - share your machine's render time here
  1. #631
  2. #632
    Jan 2004
    Stavanger, Norway
    172
    ...well, I managed 16m 59s
    Strange thing is, this time I only managed to clock the cores to 4,25 GHz - last time I did it I rendered without issue clocked to 4,5. Basically, I kept increasing voltage offset for LW not to crash, but once i reach like 1,42v, the system will not boot, not even into the bios, which is a bit troublesome. Which is a bit strange, since the voltage with spike much higher than that when it's all left to auto.
    Anyway, still loving the 3950X - just wish I could run it on Win7.
    By the way, I am using LW 11.0 - might render faster than later verisons. General rule for all software is: The newer the version, the more bloat.
    Windows 10 Pro
    Ryzen 9 3950x - 4,25 GHz
    32 Gb RAM - 3200 MHz, 14 latency
    Noctua air cooler
    max registered CPU temp: 84C (GPUZ)
    - Ignorance is bliss...
  3. #633
    Darn cool that it keeps up with the ThreadRipper.
    regarding, LightWave 2019, it is quite nice once you get a hang of adjusting the settings.
    and never import a LW2015 scene into LW2019, (for rendering) unless you know what you are doing.
  4. #634
    Jan 2004
    Stavanger, Norway
    172
    ...hmm, I see the GHz values I mentioned are wrong - I clocked the cores to 4.325 GHz, and on the previous attempt I mentioned I got them running at 4.35
  5. #635
    Super Member kolby's Avatar
    Aug 2004
    CZ, EU
    417
    Quote Originally Posted by Amerelium View Post
    Windows 10 Pro
    Noctua air cooler
    Impressive results Amerelium, could you share what you have changed in the bios to achieve these results? If I choose the OC profile, all cores runs at only 4.163 GHz, even if the temperature is only about 75C. I have a BeQuiet Dark Rock 4 air cooler (200W TDP) with two fans. With the standard profile, the temperature rarely exceeds 60C in full load so I think this shouln't be a cooling problem. My RAM sticks are the Kingston Predator 3200MHz CL16, but I don't think the latency makes such a difference. With the OC profile my time is 19m 52s in LW2015.
    System info: CPU: Ryzen 9 3950X RAM: 32GB DDR4/3200MHz MB: Asus Prime X570-P GFX: Asus GTX 750 Ti / 2GB OS: Win10, LW2019x64
  6. #636
    Jan 2004
    Stavanger, Norway
    172
    Quote Originally Posted by kolby View Post
    I assume you mean the Performance Enhancer lever 3(OC)? - that one is just for extending the use of Turbo Mode.
    you have to go further down and find the OC tuner, and change it from 'Keep Current Settings' to OC tuning. System then asks you if you want to start tuning, you say yes, and it reboots.
    When you then are back in the bios again, you can set the CPU Core Ratio manually, in 0,25 increments. This time I set it to 43,25 (so 4,325 GHz, not 4,25 as I stated in my post). Then I also increased the CPU voltage - thought be careful with that: An Intel system will just reset the bios to default if you go beyond safe levels, but here the system just fails to launch if set to high; you will not even be able to access the bios. So do not set the voltage it much beyond 1,4. I did, and only managed to get back to the bios by removing every USB devise I use, and hooking up a PS2 keyboard.
    Also note, that Windows 10 is a humongous piece of bloatware, and I have hacked the **** out of it to remove / disable as much useless junk as possible. So my system has 30ish fewer processes running than you standard Win10 setup, and that improved render times. It is still unstable, as render times will vary significantly from time to time, unlike on my previous system, where a frame would always render at exactly the same time, down to the second, unless you changed the perimeters.
  7. #637
    Aug 2004
    CZ, EU
    417
    Yes I meant Performance enhancer Level 3. I thought the OC tuner would set everything to the highest possible value automatically. I'll try it manually when I have some time. Thanks.
  8. #638
    Jan 2004
    Stavanger, Norway
    172
    You also have to set the AI Overclock Tuner to D.O.C.P for the RAM to run at 3200 MHz, if not it defaults to 2666 or 2333
  9. #639
    Aug 2004
    CZ, EU
    417
    Yeah, that was the first thing I did.
