Results 1 to 2 of 2
Thread: DeInstall older Lightwave versions
    Dec 2012
    Hamburg
    1
    I have just installed Lightwave 11.5 and I wonder how to deinstall the older versions. Can I just run the deInstaller or will it erase stuff that 11.5 might also use?
    Just make sure you install 11.5 in a new folder completely. Then move over the plugins that you might need from your old version. You should be able to treat them as separate applications at that point and just go through the uninstaller.
