Results 1 to 15 of 15
Thread: Swift3d
    Nov 2006
    Burbank, California USA
    4,576
    Swift3d
    Does Swift3 still exist for LW? Is anyone using it with 11?
    Profile piece
    2010 Reel
    'The X's' Reel
    Plays with fire sadkkf's Avatar
    Outside looking in
    1,210
    Done:
    http://www.erain.com/Products/LW/
    I haven't used it in years and now that Flash is pretty much dead, can't see much use for it at all unfortunately.
    So much water, so few sharks.
    "...all men are created equal." -- US Declaration of Independence
    Right now I need something similar for a print job where the final output is almost 20 meters long and 2 meters high so doing it as raster is a huge waste
    of resources since the thing is just a giant blueprint of white line depicting machinery. I have to use maya since LW does not offer a solution.
    Pessac
    5,051
    Why not render out a raster at a large resolution (not that large obviously) and take the render into Illustrator and autotrace to make a vectorial version?
    B
    LightWave 3D Trial Edition
    Nov 2006
    4,576
    Quote Originally Posted by sadkkf View Post
    Done:
    Thanks for the link. It looks like they stopped development.
    Profile piece
    2010 Reel
    'The X's' Reel
    Outside looking in
    1,210
    Quote Originally Posted by nickdigital View Post
    No problem. Wish I had better news for you.
    Outside looking in
    1,210
    Quote Originally Posted by bazsa73 View Post
    Can you export to OBJ and open that in Photoshop? I'm not sure if Illustrator supports that or not.
    Sep 2006
    Future Past Life
    1,899
    I believe the last version of LW it was compatible with was v9.x.
    B
    Yes I know but it's not the same still. There are lots of tiny details which would be nice to preserve. Nevertheless I use tracing for scanned machinery images but I need also
    very clean precise state of the art CGI renders as well.
    Mar 2004
    Northern New York
    5,254
    If you don't need the rendered version or the perspective version, you may be better off exporting one of the wireframe views as an eps which would then import into illustrator or photoshop.
    Quote Originally Posted by Silkrooster View Post
    Thanks! I try that.
    World's Tallest Dwarf safetyman's Avatar
    Maryland, USA
    1,343
    Be careful with Illustrator and large files like that, especially if you have text on there. I know it's vector, but Illy slows to a crawl when you get to a certain size (and I believe it has a limit on artboard size). That's why most sign companies either use tools specifically designed for large displays or something like CorelDraw, which can handle almost any size "canvas".
    Mar 2004
    Northern New York
    5,254
    I would more likely believe the number of objects and any raster images or effects would affect the speed before the size of the document would. I can see hitting the limit but for the speed its the same number of vertices whether its large or small.
    Thanks for the extra info guys, I guess I will just scale up the thing when it's done.
    Maryland, USA
    1,343
    Obviously, the more stuff you put in the document will affect it's size. Something to remember also is that Illustrator CS6 has a max document size of 227.54 inches. Back when I was using CorelDraw (version 8), I could go much, much bigger, like 120+ feet.
