Page 1 of 5 123 ... LastLast
Results 1 to 15 of 69
Thread: RH Animation Tools
    Nov 2003
    jersey
    5,792
    RH Animation Tools
    So... here's a more finished collection of pluings/tools Ive been putting together for all the animators out there...
    edit... Just updated the zip here (15:07gmt) to make a change to the key reducer (and the embedded version in baker)... it now only deletes fixed keys between hold positions (leaving the out point key) handy if you want to use it for non baked motions).
    Rebel Hill Animation Tools.
    A set of simple tools to help with common animation tasks and needs.
    RH_HoldFlat;
    We should be familiar with the situation where you key something, lets say at frame 0, then key it again at the same place at say frame 10... Then we move and key it at frame 20. If we're using TCB curves by default, we get a drift happen between 0-10... our HOLD keys.
    This script will flatten out those hold portions automatically for all channels of the selected item(s).
    RH_ReduceKeys;
    A simple key reducer to get rid of extraneous keyframes, intended mainly for cleaning up key curves after baking. No different to the reduce tool built into graph editor, but is often faster to use due to GE's slow speed at selecting large numbers of channels for large numbers of items (such as when reducing keys for a baked character rig).
    RH_EulerFilter;
    A simple Euler filter for fixing the "flipping" that occurs after baking curves in the channels of items which have used various motion controlers/constraints. Important for fixing things that will be rendered with motionblur, or exported to game engines, or the like.
    RH_MotionBaker
    This plugin bakes motion to keyframes for a group of selected items. Bakes any motion that can ordinarily be baked to keys using LightWave's regular per item Motion Baker plugin, or who's motion records via manual keyframing. This tool also contains implementations of the other tools above to give you a one stop shop for baking and cleanup.
    Enjoy.
    RH.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Registered User sami's Avatar
    TopLeft Viewport
    1,079
    Excellent stuff - very handy. The motion baker works a treat! I hereby recommend everyone go buy Rhiggit & your RHR videos as a thank you.
    Yes, handy.
    Thank you very much
    Kev xx
    Nov 2003
    jersey
    5,792
    btw... theres an updated version of the baker in this package... which the extra bits built in.
    RHN Nodal Tutorials
    Banned OnlineRender's Avatar
    Dec 2008
    Glasgow , Scotland , UK
    6,382
    RH_HoldFlat;
    that my friend is a god send
    Registered User Marius Roth's Avatar
    Oct 2005
    HamburgGermany
    18
    Thanks! Especially HoldFlat is a %&$-Dream
    Thanks, RH! Those are very useful!
    Dec 2008
    Ghana West Africa
    869
    Awesome! This is a dream come true.
    Thanks bunch, RH!
    Registered User Kaptive's Avatar
    Jan 2006
    UK
    776
    Flipping awesome, many thanks! Big love care bear style over to Jersey!
    I already bought RHiggit though so I will just say thanks
    Awesome stuff.
    Poly abuser pablogrca1's Avatar
    Nov 2004
    Hannibal, Missouri
    114
    Same here, bought RHiggit but still many thanks Craig!
    Words to live by. "If at first you don't succeed, try, try again."
    ___________________________________________
    www.plushpixel.com
    v11.6.3
    Nov 2003
    jersey
    5,792
    Well, cheers. So very glad you all like 'em.
    As for those of you who do indeed have RHiggit, I started stringing these tools together initially as add-ons for RHiggit, to help quicken workflow, or automate certain tasks... The Motion Baker is THE tool for finalising an animation done on an RH rig... select all deform bones, and run baker (ideally with default options), delete your control structures and send to render. It also makes a great tool to use with the FBX-IK rig. Get your mocap loaded onto the rig in LW, select the control items and bake (perhaps even with a frame step to give pseudo-handKeying), and switch out to the control rig and edit away. Its even got a custom lil hook in there for the FBX-IK to prevent you having to run the double bake to capture the updated motions for the spine system.
    Cheers.
    RHN Nodal Tutorials
    Thanks!!! now we need a quick way to switch from TCB to Linear and Stepped like Maya's and this will be an animators Playground !!!
    Nov 2003
    jersey
    5,792
    Quote Originally Posted by Samus View Post
    I can do that...
    RHN Nodal Tutorials
    Createkey plus can do this.. Though, for more than just one keyframe I haven't looked at what is out there.
