Thread: Bones deforming the wrong mesh!!
    Apr 2012
    Montreal
    17
    Hi everyone,
    I've rigged a character and applied IK Booster. When I move any bone, everything is fine. However, when I move one of the leg bones, it deforms the wrong mesh. I've already tried re-doing the weightmaps, in case I accidentally included a point from the wrong leg, but its still the same problem. I've posted a picture of the problem deformation. Thank You for help!Click image for larger version.
ID:	110072Click image for larger version.
    Oct 2003
    Orlando, FL
    4,146
    You have the bones set to use only the weightmap?
    If not, have you adjusted the influence of the bones?
    If you can package and attach the scene it is usually best for people trying to help. That way they can see what you have done rather than guess at what you might have done.
    Nov 2003
    jersey
    5,766
    Must be a weight issue... or u have bones with no weight assignment, in which case they effect all verts.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Apr 2012
    Montreal
    17
    Thank you all!! It finally got fixed when I set the subpatch level back from 0 to 3. And yes, I had one unassigned bone on each leg, so that was the problem too. Thank!!
