Results 1 to 15 of 25
Thread: Thickness checker
    Thickness checker
    I was wondering if anyone knew of a Modeler plugin that could check the thickness of your model. Like for printing purposes, if you had an area that was thinner than say, 1mm, those points could be colored differently like a weightmap is. This way you could easily select those points and use tools like Point Normal Move to add thickness.
    ~~Phil Nolan
    I don't know if you use LWCAD Phil but that sounds like a good feature request for Viktor.
    I do have LWCad, though I haven't been able to upgrade, I'm still on v3.62.
    ~~Phil Nolan
    Sep 2008
    Wichita Kansas
    41
    Read an article that addresses a procedure to check thickness of a model meant for 3D printing.
    http://www.3dartistonline.com/news/2...r-3d-printing/
    Thanks, my idea actually came from the printing site Sculpteo.com, they have a checker on their site. I just thought it would be easier to have it right in LightWave so that you didn't have to jump back and forth between programs
    Sculpteo's version:
    ~~Phil Nolan
    areté adk's Avatar
    Melbourne
    1,505
    This sort of setup might do what you need, tho not for all occasions I imagine (as shown in the gif).
    adk.
ID:	109795   Click image for larger version.
ID:	109796   Click image for larger version.
    Hmm. I'm terrible with nodes. Would this allow you to enter a specific size?
    ~~Phil Nolan
    areté adk's Avatar
    Melbourne
    1,505
    Quote Originally Posted by Philbert View Post
    Yup ... the positions of the keys in the gradient correspond to meters in this case. You can also stair-step your keys so you don't get a gradient but discreet colours. I used a similar setup for a court case to analyze differences in height between two mounds of earth (a before and after) - I sure hope that it's correct as getting it wrong would mean ... a lot of headaches for me
    Is it easy enough to explain how to change the measurement unit, like from your meters to millimeters? It would still mean a little jumping back and forth since this wouldn't show in Modeler, but it's not so bad since the hub handles it for you.
    ~~Phil Nolan
    hm, nice challenge :]
    not sure if sigma could be good for something...
    putting an illuminated wall inside the hollow object and using radiosity might work...
    http://forums.newtek.com/showthread....=1#post1096576
    Remember Wade's Avatar
    Cypress Texas
    1,385
    You can set up a surface with a thickness gradient, but I think that works from the cameras point of view. Color / Layer type - Gradient - input parameter - Surface Thickness.
    http://www.imagecommunications.de/tu...thickness.html
    Shuttle XPCVista 64 bit /Core2Extreme x9650 3.00GHz 8GB GeForce 8800 GTS 512 Cintiq 21UX
    Dell 24" LCD Dell XT2 Tablet /Win 7 32 Bit /Core 2 duo SU9600 1.6 GHz 3GB / Mobil Intel 4500MHD
    I could've used that tutorial for my recent iced tea scene.
    ~~Phil Nolan
    areté adk's Avatar
    Melbourne
    1,505
    The whole node flow is quite simple in this case Phil. What you're basically doing is getting the mesh's smoothed surface normals & flipping them (that's what the multiply node does with -1 in all x/y/z directions), then you're tracing a ray from each spot on the surface, in the direction of these flipped normals ( which now point inside the mesh ) & analyzing the length of these rays. The result of this is then plugged into the gradient which gives you quite precise analysis.
    If you need mm instead of meters all you need to do simply add a scalar multiply node (and multiply it by 1000) before plugging into the gradient.
    If you post a small object example of what you have in mind to measure I'd be happy to set this all up for you mate. What version of LW you on btw ?
    PS: I think you'd need a specific plugin for this to work inside of modeler. Layout is your best friend in this case I'm afraid.
    Thanks. I'm on 11.0.3 (x64). I made a test object that you can play with too. Just a cylinder with several different thicknesses. I'll try out the flow. I'm not sure I need it right now anymore but for any future printing jobs I or anyone else have it would be useful.
    Attached Files Attached Files
    ~~Phil Nolan
    Cypress Texas
    1,385
ID:	109810Click image for larger version.
ID:	109809Click image for larger version.
    Just useing the gradient settings and ortho camera.
